Topic: full adder/subtracter with carry (Read 4359 times) previous topic - next topic
z2012
I have 2 8bit bytes that come in from the SPI. I need to add or subtract a 1 to the bytes. So I need help with a code that can add to the lower byte and be able to carry into the high byte when necessary. I also have no idea how to subtract.
The other option is a increment/decrement system for the 16bits.
This is simple using chips. :smiley-roll:
Arrch
Thats a simple if statement. After you add, check if the new value is 0. If so, add 1 to the high byte. Alternatively, you can use a union.
AWOL
Quicker too.
el_supremo
Just construct a 16-bit integer with the hi and lo bytes, add 1, and you're done.
Pete
Don't send me technical questions via Private Message.
PeterH
In my opinion this is the only approach that makes sense. From the description you've given it's apparent that the two bytes are conceptually holding a 16-bit value, so if you just store that value in a 16-bit int then manipulating the value becomes trivial.
z2012
The 2 bytes is incremented up or down by 1 then sent back out on the SPI lines. As far as I know SPI wants 8bit binary bytes.
Arrch
Then use a union.
#7
Jun 28, 2013, 11:03 pm Last Edit: Jun 30, 2013, 04:47 pm by JimEli Reason: 1
add:
unsigned char low, high;
  //add 1 with carry
 asm(
   "lds r24, (low)  \n\t"  //low byte
   "lds r25, (high) \n\t"  //high byte
   "ldi r23, 1      \n\t"
   "add r24, r23    \n\t"  //increment low byte by 1
   "adc r25, 0x00   \n\t"  //add carry to high byte
   "sts (low), r24  \n\t"  //save results
   "sts (high), r25 \n\t"
   ::: "r23","r24", "r25"
  //subtract 1 with carry
  asm(
    "ldi r23, 1      \n\t"
    "sub r24, r23    \n\t"
    "sbc r25, 0x00   \n\t"
    ::: "r24", "r25"
Edit note: for completeness I included the subtraction code. My original thought was that the OP was requesting an assembly language routine.
PeterH
So, put them into an int, modify the int and then take them out again. Converting between a pair of bytes and an int is quick and easy.
nickgammon
add:
 asm(
   "ldi r23, 1      \n\t"
The compiler can handle adding one to an integer. You don't need to drop into assembler for that. ;)
nickgammon
Perhaps show your existing code?
z2012
highbyte = B00000000; //cmd0 NOP to read control SDO
        lowbyte = B00000000;
        digitalWrite(SSP, LOW);
        rdacsethigh = SPI.transfer(highbyte); //sent cmd0
        rdacsetlow = SPI.transfer(lowbyte);   //and read SDO
        digitalWrite(SSP, HIGH);
Sorry I am an electrical engineer, im not into software. How do I convert into and out of the integer?
PeterH
int tmp = word(highbyte, lowbyte);
tmp++;
highbyte = highByte(tmp);
lowbyte = lowByte(tmp);
It could be made more compact but you get the idea.
z2012
Thank you PeterH, what you did makes sense.
