Topic: [SOLVED] Project 3: Serial.print(float) hangs Arduino (Read 6387 times) previous topic - next topic
gmf811
Jun 30, 2013, 12:58 pm Last Edit: Jun 30, 2013, 02:18 pm by gmf811 Reason: 1
EDIT: Rebuilding cross-avr/gcc with multilib enabled fixed everything that follows...
Hi all, I'm having some teething troubles completing project 3 - "love-o-meter".
Completing the code exactly as per the book, the Arduino reboots, the onboard LED (pin13) lights up and nothing else happens. Mucking about with the code it seems that if I try Serial.print(floating point number) the board fails to pass setup() and locks up. I can work around it (sometimes) by casting to integer, although again it seems to be rather fragile.
As I can only find one other thread from 2010 describing this issue, I suppose it's not a common problem.  Please could someone give me some advice on what in my setup is likely to be causing this?
System: Linux 3.8.13-gentoo x86_64
Arduino version: =dev-embedded/arduino-1.0.5
RXTX version: =dev-java/rxtx-2.2_pre2
Some code:
Code: [Select]
// Constants
const int sensorPin = A0;
const float refTemp = 25.0;
 for(int pin=2; pin<5; pin++){
   pinMode(pin, OUTPUT);
   digitalWrite(pin, LOW);
 /* I set up Pin13 driven LOW to confirm that
    the board successfully passed setup().
    When I try to write Serial.print(floating point)
    later in the project, Pin13 stays high suggesting
    that it doesn't pass setup() */
 pinMode(13, OUTPUT);
 digitalWrite(13, LOW);
 int sensorVal = analogRead(sensorPin);
 Serial.print("S: ");
 Serial.print(sensorVal);
 Serial.print(", V: ");
 float v = (sensorVal/1024.0) * 5.0;
 float t = (v - 0.5) * 100;
 // Uncomment the below to hang the Arduino
 //Serial.print(v);
 /* I moved the last bits of Serial.print
    below the LED code so that I could work
    on the temperature and voltage variables
    without having to edit this */
 if(t<refTemp){
   digitalWrite(2, LOW);
   digitalWrite(3, LOW);
   digitalWrite(4, LOW);
 } else if(t>=refTemp+2 && t < refTemp+4) {
   digitalWrite(2, HIGH);
 } else if(t>=refTemp+4 && t < refTemp+6) {
   digitalWrite(3, HIGH);
 } else if(t>=refTemp+6) {
   digitalWrite(4, HIGH);
 /* The following works:
 Serial.print(", mV: ");
 v = v*1000;
 Serial.print(int(v));
 Serial.print(", T: ");
 Serial.println(int(t));
 /* The following workaround assembles T as
    two integers with a text decimal place
    but if I do this then I can't print
    v or int(v) without a lock up.
    I certainly can't have both t and v to
    two decimal places.
 Serial.print(int(t));
 if(t>0){
   t = t - int(t);
   t = int(t) - t;
 t = t*1000;
 Serial.print(".");
 Serial.print(int(t)); //Serial.println() here would hang the Arduino again
 Serial.println("degC");
 // Heartbeat, slows readings to 2s
 digitalWrite(13, HIGH);
sats
I have the same issue and I don't understand how to rebuild... rebuild what exactly? I'm only familiar with the IDE so far. Could you point me in the right direction please?
