Topic: windchill formula uses exponents, how do we do that? (Read 4758 times) previous topic - next topic
grendle
the windchill formula uses exponents
Windchill  = 35.74 + 0.6215*T - 35.75(V^0.16) + 0.4275*T(V^0.16);
where T is temperature
V is wind speed
^0.16 is an exponent.
this is the layout from the nws site but ofcourse the ^0.16 is giving errors on compile, can someone help me please?
grendle
#2
Jun 30, 2013, 10:40 pm Last Edit: Jun 30, 2013, 10:51 pm by grendle Reason: 1
most awesome of you. thank you  very much JarkkoL.
for reference, works fine tested with nws windchill calculator
the 2 float values temperature and windspeed are just test numbers, i dont have an anemometer? yet.
void setup(){
float T=49;
float V=10;
float Windchill  = 35.74 + 0.6215*T - 35.75*pow(V,0.16) + 0.4275*T*pow(V,0.16);
Serial.print(Windchill);
void loop(){}
Henry_Best
V is wind speed
As 35.74 and 35.75 are very nearly equal, this formula could be rewritten as
Windchill  = 35.74(1 - (V^0.16)) + T((0.4275(V^0.16)) + 0.6215) with very little error.
grendle
V is wind speed
much appreciated henry, thank you kindly. i will certainly experiment with this info  XD
robtillaart
#5
Jul 01, 2013, 09:47 pm Last Edit: Jul 02, 2013, 07:00 pm by robtillaart Reason: 1
Ans as V^0.16 is used twice one could store it in a variable so it can be reused iso recalculated.
this prints a lookup table for diff values of T and V
 for (int T = 0; T < 100; T++)
   for (int V = 0; V < 15; V++)
     float tt = pow(V, 0.16);
     float Windchill  = 35.74 + 0.6215*T - 35.75*tt + 0.4275*T*tt;
     Serial.print("\t");
   Serial.println();
Rob Tillaart
grendle
      Serial.print("\t");
    Serial.println();
very nice Rob, im gonna have to start paying you lol thats twice you rescued me from math  :D. this is sweet and this is the format im gonna use. thank you.
robtillaart
Please note that tt = pow(V, 0.16); is called 1500 times in the above example for only 15 different values, that is rather inefficient math - but yes it could be worse ;)
Rob Tillaart
PaulS
I'm pretty sure that the compiler would notice that, too. In the machine code, that would have been moved out of the inner loop, since in that loop the value never changes. Unless V or tt are marked volatile.
robtillaart
V changes in the inner loop, thats why it is called 1500 times see code below
int x = 0;
      float tt = pov(V);
      Serial.print(tt);
      Serial.print("\t");
    Serial.println();
  Serial.println(x);
float pov(float V)
  x++;
  return V * V;
This would be more efficient;
float lookupPow[15];
  // fill the lookup array
    lookupPow[V] = pow(V, 0.16);
      float tt = lookupPow[V];
      Serial.print("\t");
    Serial.println();
there are more optimizations possible but they are outside the scope of this thread.
Rob Tillaart
