Topic: GSM.begin hangs (Read 3439 times) previous topic - next topic
armin
I have a problem with the GSM.begin function about 50% of the time it hangs. I have a electric sheep (atmega 2560) from sparkfun with the gsmshield on top. I feed it 12V 1A externally.
It appears if the communication with the GSM just stops most of the time. On a few occasions I see a few garbage bytes over the serial line.
I have included a snippet of the code where I added a small delay and almost stock example code. I have also included a successfull and a failed start attempt. Does this problem sound familiar?
Code: [Select]
boolean notConnected = true;
  for(byte i=0; i< 5; i++)
    Serial.println(i, DEC);
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
      //wdt_reset(); // Reset the WDT
Success
Code: [Select]
AT%13%
0 9>AT%13%%13%%10%OK%13%%10%
AT+CPIN=7130%13%
9 44>AT+CPIN=7130%13%%13%%10%+CPIN: READY%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
44 75>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
75 120>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%Call Ready%13%%10%
AT+CGREG?%13%
120 23>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
23 54>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
54 85>AT+CGREG?%13%%13%%10%+CGREG: 0,1%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
85 102>AT+IFC=1,1%13%%13%%10%OK%13%%10%
AT+CMGF=1%13%
102 118>AT+CMGF=1%13%%13%%10%OK%13%%10%
AT+CLIP=1%13%
118 6>AT+CLIP=1%13%%13%%10%OK%13%%10%
ATE0%13%
6 17>ATE0%13%%13%%10%OK%13%%10%
AT+COLP=1%13%
17 23>%13%%10%OK%13%%10%
GSM initialized
Number: +316********
Message:
Arduino test SMS
AT+CMGS="+316********"%13%
23 27>%13%%10%>
Arduino test SMS%26%%13%
23 46>%13%%10%> %13%%10%+CMGS: 11%13%%10%%13%%10%OK%13%%10%
Send 16bytes Return endSMS()1
COMPLETE!
Fail
Code: [Select]
AT%13%
AT+CPIN=7130%13%
AT+CGREG?%13%
AT+CGREG?%13%
armin
I looked into the library and added a debug message which I see on my screen. It seems that the modem never returns ready. Is this a very save way to code it this way? since it can easily lead to infinite loops.
Code: [Select]
// Begin
// Restart or start the modem
// May be synchronous
GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char* pin, bool restart, bool synchronous)
pinMode(__RESETPIN__, OUTPUT);
// If asked for modem restart, restart
if (restart)
HWrestart();
HWstart();
theGSM3ShieldV1ModemCore.gss.begin(9600);
// Launch modem configuration commands
ModemConfiguration(pin);
// If synchronous, wait till ModemConfiguration is over
if(synchronous)
// if we shorten this delay, the command fails
while(ready()==0)
Serial.println("gsm.begin() waiting for ready");
return getStatus();
davidgoth
The problem is similar to one that occurred because a lack of electrical power to register on the GSM network. Can you confirm that modem continues on?
armin
I think it was a power issue. The electric sheep claimed 1.5A which should be sufficient.
I am working the last week with our own PCB design and I have not seen this problem. So problem solved I guess.
33bert51
%13% est affiché dans la méthode GSM3ShieldV1ModemCore::writePGM
if (CR)
print("\r"); --> affiche %13%
