Topic: Science fair project - flashlight (Read 6014 times) previous topic - next topic
robtillaart
For all those students searching for a graduation project, they should watch this idea from a 15 yr old
- http://www.youtube.com/watch?v=fRdeFcIK8QM -
Think it is great!
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
nickgammon
Wow. And outside on a cold night it would be brighter. Pretty good.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
westfw
Another video with more technical content: http://www.youtube.com/watch?v=9CCGUMkcbjg
Unfortunately, the technical content includes quantitative data; she gets about 5mW; enough to run each of the 3 LEDs at about 0.5mA each.
That makes it a pretty great science fair project, but not a very practical flashlight.
Coding Badly
I disagree.  At 1:40 she claims "five foot candles of brightness" which, according to the OSHA and Phillips websites, is bright enough to move about but not bright enough to work (about right for an emergency flashlight).
robtillaart
Quote
Maybe with the help of some components (switch capacitor ...) one could extend the device to have a "harvesting mode" to collect energy and a "shine mode" to use the energy.
Or connect several "harvesters" to one group of leds.
I was also thinking of a "head-band" version...
Rob Tillaart
radman
Not verbatim but I think I got the key points;
Quote
40s Step1: How much heat per cm sq our bodies radiate, I found this to be around 5mW
I needed only 0.5mw to obtain a good LED brightness.
55s Step2: Characterisation of the peltier tiles, I found that both tiles produced sufficient energy but only around 2mV,
I needed around 2.5V
1:07s Step3: final circuit has only 4 components. I obtained a good LED brightness with less than a 50mV input and around a 50% efficiency.
1:20s Last Step: 5mW of power 5 foot candles of brightness
No moving parts, no charging required, simple construction, I like this.
How do the numbers in the above stack up, could people use this to move about safely at night and how cheaply could it be produced?
nickgammon
What I am curious about is how 2mV became 2.5V, especially with only 4 components. How would that be done?
westfw
Step 2 said "a few millivolts", not "2"; later she says her step-up runs from 50mv input.  (which is quite impressive, BTW.   Most step-up circuits need an input voltage of at least a transistor Vbe; about 600mV.) (Hmm: http://circuits.linear.com/64 )
"foot candles" is a lousy way to measure light output.
Quote
It's hard to say.  Those single-LED keychain lights are generally around 100mW;  I've been in situations where they seem ridiculously bright, and also situations where they were not nearly enough (keychain lights are NOT sufficient for exploring lava tubes!)  Arguably, the light of the full moon is enough to "move around safely", and it's pretty dim.
One of the nice things about this, as a "science fair" project, is the fact that most people should be able to reproduce the results.
radman
She said the peltiers gave 2mV and at the end she said she got good brightness with only 50mV though she wanted 2.5V.
Would 50mV give a good brightness.
She mentioned 50% efficiency. Did she mean she only obtained 50% of the 5mW/cm sq she thought the body produced?
Is 5mW/cm sq reasonable?
At the end of the day she showed a working torch. The output looked poor but it looked on the verge of being usable.
radman
Quote
So the circuits, calculations etc. will be published?
Do you know where?
westfw
This looks pretty complete: https://www.googlesciencefair.com/en/projects/ahJzfnNjaWVuY2VmYWlyLTIwMTJyRAsSC1Byb2plY3RTaXRlIjNhaEp6Zm5OamFXVnVZMlZtWVdseUxUSXdNVEp5RUFzU0IxQnliMnBsWTNRWXA2ZVVBZ3cM
GoForSmoke
You see the bulbs against dark in the video. You don't see them illuminate anything but the camera element. Try lighting a white led with 2.5V at 2mA (5mW)... she uses 3.
I'd like to see a bigger one with a cap so it can be filled with cool or cold water.
A hat or headband with peltiers on skin (forehead and temples) would give more area and heat, 30% of your body heat goes out through your head (a good hat in the cold is worth a lot), body heat is not the same for all skin. Our brains are real pigs.
Also check the inside of the wrist as opposed to the palm, and armpits (where you put your cold hands to warm them up even through a coat) and some other places I won't mention.
Areas with fat won't do so well though.
If you could get significant area, you could really be bright.
Getting around in the woods at night without a flashlight was one thing we learned in Scouts back in the day, but there's some nights when a light like that would really help like no moon and overcast/raining. I spent my last 3 or so years in Scouting without one, camping every month and one summer over 8 weeks and never missed having one.
Give your eyes time to adjust, you'll be surprised at how much wider and less claustrophobic the view is without a damned flashlight.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
robotlover17
If this gets second place.. then what does a 15 year old need to do in order to win? Invent the next iphone? I'm very impressed!! :)
nickgammon
She could call it the iTorch. :)
Powered by "I".
Coding Badly
Deep within the bowels of Apple, a corporate lawyer's trident just flickered red.
