Topic: Arduino Due Operating Temperatures (Read 1 time) previous topic - next topic
haturi
Hello,
I am considering Arduino Due for an outdoor project where the temps can go down to 20F (-7C).  Would the board work at that temperature?
I can shelter it from weather by putting it in a box, thermal insulation, etc if necessary.  There are 50+ components on that board and I hope the designers had done their home work by making it reasonably tolerant to outdoor temps.
Thanks.
graynomad
Quote
Maybe, but I wouldn't bet on it. I've never seen any quoted temp ranges.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
haturi
There may be a way to find that out.  Requires identification of each and every logic component on the board.  I came across a site from Italy where there is a pretty high res image of the board and most components are clickable.  It points to the URL for data sheet inside a list of URLs for data sheets when you click one.  One more click and you can access the data sheet.
However, exact chip identification is necessary for a particular board.  That, with the possibility of the board being made in different places, makes the job pretty hard.
I would be nice to know if a Due maker had ever put the board in a thermal chamber.
