Topic: how many clock cycles take this code to be executed? (Read 936 times) previous topic - next topic
eng_mac
hallo everybody,
i am impeleneting a protocol on arduino due and timing is very important , i want to know
how many clock cycles or the time in microsecond take this code to be executed?
  if (counts >=0 && counts <=80) b1 = 1;
  else if(counts >=330 && counts <=410) b1 = 2;
  else if(counts >=450 && counts <=530) b1 = 3;
  else if(counts >=820 && counts <=1024) b1 = 4;
and how many clock cycles take the for loop to check condition and make anew loop?
Thanks
Gericom
If you exactly want to know how long a piece of code takes, you're better off with asm. Because you never know what a compiler will produce.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
schwingkopf
what about:
Code: [Select]
int t1, t2;
t1 = micros();
t2 = micros();
Serial.println(t2-t1, DEC);
Of course there should be a "Serial.begin(115200);" command in your setup routine. You should mind that your code execution time depends on the value of "counts" (for counts = 60 only the first line is executed, for counts = 1000 all 4 if's are evaluated). To get the worst case you should ensure proper values for "counts".
I guess your code will take about 4 usec (in worst case), so you have to take into accout that the "micros()" commands take about 1usec each, so you will measure something like 6 usec.
If you want to improve your accuracy you can recopy your code several times between the two micros() commands and divide the final number accordingly. If you want to measure properly below 1us you need to set digital channels using port manipulation before and after your code and measure with an oscilloscope...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
