Topic: Clone Nunchuk initialisation problems [FIXED] (Read 2115 times) previous topic - next topic
acboother
Jul 02, 2013, 05:48 pm Last Edit: Jul 02, 2013, 08:46 pm by acboother Reason: 1
[FIX]
A delay between requestFrom and available makes it work  :smiley-yell:
I tested briefly with delay(1) and still looks good. MEGA irritating as my son would say
Code: [Select]
  Wire.requestFrom (0x52, 6);
  delay(10);
  while (Wire.available ())
[/FIX]
I am reposting this from "Sensors" as it seems to have generated no reaction.
I have just received a MadCatz.com Nunchuk and I am unable to initialise it.
I have another Nunchuk clone and an official Nunchuk which I can initialise and read.
I have tried all I can find on the Internet and they are shown below and none have worked.
'Official' Nunchuk code
Code: [Select]
 Wire.beginTransmission (0x52);
 Wire.write (0x40);
 Wire.write (0x00);
 Wire.endTransmission ();
and this which works for my clone and the official Nunchuk
Code: [Select]
 Wire.beginTransmission(0x52);
 Wire.write(0xF0);              // 1st initialisation register
 Wire.write(0x55);              // 1st initialisation value
 Wire.endTransmission();
 delay(10);
 Wire.write(0xFB);              // 2nd initialisation register
 Wire.write(0x00);              // 2nd initialisation value
I have also tried
Code: [Select]
 Wire.beginTransmission(0x53);    //WM+ starts out deactivated at address 0x53
 Wire.write(0xfe);                 //send 0x04 to address 0xFE to activate WM+
 Wire.write(0x05);
 Wire.endTransmission();          //WM+ jumps to address 0x52 and is now active
and
Code: [Select]
 Wire.write(0xfe);
 Wire.write (0x05);
and this one which is getting more sophisticated
Code: [Select]
// params:
// timeout: abort when timeout (in ms) expires, 0 for unlimited timeout
// return: 0 == ok, 1 == timeout
byte x2nunchuck_init (unsigned short timeout)
 byte rc = 1;
 unsigned long time = millis();
 do
   Wire.beginTransmission (0x52); // transmit to device 0x52
   Wire.write (0xF0); // sends memory address
   Wire.write (0x55); // sends data.
   if(Wire.endTransmission() == 0) // stop transmitting
     Wire.write (0xFB); // sends memory address
     Wire.write (0x00); // sends sent a zero.
     if(Wire.endTransmission () == 0) // stop transmitting
       rc = 0;
 while (rc != 0 && (!timeout || ((millis() - time) < timeout)));
 return rc;
and finally this most complex one
Code: [Select]
void  nunchuck_init ()        {
 // init controller
 delay(1);
 Wire.beginTransmission(0x52);      // device address
 delay(1);
 delay(1);
 // read the extension type from the register block
 Wire.write(0xFA);                    // extension type register
 Wire.requestFrom(0x52, 6);               // request data from controller
 for (cnt = 0; cnt < 6; cnt++) {
   if (Wire.available()) {
     pwbuff[cnt] = Wire.read(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck
 delay(1);
 // send the crypto key (zeros), in 3 blocks of 6, 6 & 4.
 Wire.write(0xF0);                    // crypto key command register
 Wire.write(0xAA);                    // sends crypto enable notice
 delay(1);
 Wire.write(0x40);                    // crypto key data address
   Wire.write(0x00);                    // sends 1st key block (zeros)
 Wire.write(0x40);                    // sends memory address
 for (cnt = 6; cnt < 12; cnt++) {
   Wire.write(0x00);                    // sends 2nd key block (zeros)
 for (cnt = 12; cnt < 16; cnt++) {
   Wire.write(0x00);                    // sends 3rd key block (zeros)
 delay(1);
 // end device init
Although I can get back a set of data from the Nunchuk it is all the same and never changes I thought that I must be reading something but I'm not so sure now...
I ran up the scanner test sketch and it doesn't find any I2C devices when this clone is plugged in. Does this help identify the cause and possible solution BUT I dug out the Wii and it works on the Wii okay.
acboother
Diagnostic update...
I didn't notice this first time round but after the intialisation routine immediately after uploading the Nunchuk does NOT read correctly but hangs!!!
If I unplug the Nunchuk and then plug it back in without a reset or upload it starts to read but it is now that the values do not change.
Using this initialisation routine
Code: [Select]
and registers 0x32 and 0x33 for reading
<I promised myself I wouldn't look it this again until I ha some new information to work with...  :smiley-sad-blue:
acboother
I have put a 'scope on the SDA and SCL pins for both the official Nunchuk and the clone an as far as I can tell they both look the same (mind you I barely know what I'm looking at).
Here is the trace from the clone
So something similar is going on for both controllers
