Topic: Need advice on programming articles (Read 825 times) previous topic - next topic
frodofski
Hi everyone,
I've been working with my Arduino for over two years now, at home and at college, and I feel I've gotten pretty good at programming. Because of this, I decided to write a few articles to help get newer Arduino programmers into some of the more advanced features of the Arduino and microcontrollers in general.
Here is my first article.
I have quite a list of things that I want to write about, so I was hoping I could get some feedback or advice on this article so I can write my future articles even better.
Thanks.
AWOL
Quote
Firstly the sensor value is read into the 'reading' variable. This could take up to a few hundred microseconds.
Except for the first reading, about 100 microseconds. (13 cycles of a 125kHz clock)
Not "a few hundred microseconds".
The first will take about 200 microseconds. (25 cycles of a 125kHz clock)
Quote
Next, the 'reading' variable is then sent via Serial comms to the computer. Depending on the baud rate, this could take up to a few milliseconds to complete.
Since about Arduino 1.0 the output is buffered, and will be sent out during the "delay()", so the completion time will be during the delay.
Code: [Select]
ISR(TIMER1_COMPA_vect)
  // Code in here gets executed every time the counter
  // reaches, in this case, 6250 (every 100 ms)
  reading = analogRead(sensorPin);
IMO, an ISR is not the place to be doing an analogRead. Too slow.
Initiate a read in an ISR and interrupt again on completion, but don't sit in an ISR doing a busy-wait.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
frodofski
Thanks AWOL.
Quote
Code: [Select]
Yeah I see what you mean. I was trying to keep things simple by just using the analogRead function, but what you said would be much better.
