Topic: Yet another SSR topic (Read 5648 times) previous topic - next topic
enen92
Hi all,
First of all my apologies to bring again another topic about solid state relays. I've bought the starter kit and completed all the beginners projects included in the kit, so I think I have now what is required to start moving forward to something more close to a proper use of Arduino.
I'm thinking about buying some SSR to control some 230VAC devices (lamps mainly). I know how to choose them according to the main line voltage/amperage and also to the arduino's side "limitations". My question is about a way to find if the main circuit is connected from the arduino side. For example, if I decide to connect a SSR to a lamp and to the arduino how can I know if the lamp is turned on from the arduino if I switch the lamp on through a switch connected in paralel with the relay?
An SSR is a "special kind" of octocoupler, so it has a LED. Does this mean that if the main circuit is on (switched from the arduino or from the mechanical switch) the SSR led will always be on and that the value I get from the arduino digital pin is always HIGH? Or on the other I can only turn the SSR led on from the low DC power side?
Regards and thanks in advance for all the help you may provide
Grumpy_Mike
Quote
Basically you can't without providing an opto coupler in the reverse direction.
Quote
No it is not.
Quote
No
sonnyyu
I think I got what you concerned. It is perfect point.
The led of SSR has life span. if SSR is on most of time, your idea will help a lot for extend led life span. and implementation is easy and just inverter opto-isolator. However at practical is no go,  the deal stopper is low DC power side power failure will cause high AC side is on. It is not acceptable.
sonnyyu
#3
Jul 04, 2013, 01:39 pm Last Edit: Jul 04, 2013, 01:41 pm by sonnyyu Reason: 1
What you ask is AC voltage/current sensor or monitor. We have some thread about it, see if it is helpful, otherwise post back here we will sharp the pencil.
http://forum.arduino.cc/index.php?topic=162326.msg1277450#msg1277450
Grumpy_Mike
Quote
WTF is that supposed to mean? It is gobbledegook at best totally wrong at worst.
sonnyyu
WTF is that supposed to mean? ...
Is that your standard way to speak at public forum?
retrolefty
Well his name does start with Grumpy  ;)
How about you just restate whatever you were trying to say as it wasn't at all clear to me also. Or not if you so wish.
Lefty
Grumpy_Mike
No it is a special term I reserve for members who give irrelevant and wrong advice persistently despite several previous warnings.
Let's try and pick the bones out of your comments. I will assume that you are not a native English speaker so lets not dwell on things like sentence construction although it does make things hard to read.
Quote
A power failure on the DC side, I assume that is the LED side would not result in the AC side being on, it would result in the triac not being triggered and so no conduction would take place, the same situation as when it were off. So your comment here is just plain wrong.
Quote
The LED in an SSR is the most reliable component in the circuit and so the least likely to fail so extending the life span on it is not going to affect the overall performance of the component.
PLAN F
Only post when you know what you are talking about. If you are not sure on a topic and still feel you would like to contribute then acknowledge the fact in a preamble, like I am no expert but ... or I think you might ....
Remember, I have told you before, this is a beginners forum and it is incumbent upon you to give clear, accurate, relevant advice, not flights of fancy.
From the OP
Quote
Yes that is correct.
sonnyyu
#8
Jul 04, 2013, 07:07 pm Last Edit: Jul 04, 2013, 07:19 pm by sonnyyu Reason: 1
Lefty
Sure;
DC turn on; AC turn on.
DC turn off; no current through LED, AC turn off.
But led life span if on time is long.
By Inverter opto-isolator;-
DC turn on; AC turn off.
DC turn off; no current through LED, AC turn on.
The led life span is good now, but in case DC side power failure then AC keep turn on. It is the deal stopper.
sonnyyu
You get that right;-
English is my third one, among Chinese, Japanese.
My next one and I wish not last one is;-
?   d7 93        HEBREW LETTER DALET
?   d7 a0        HEBREW LETTER NUN
?   d7 99     HEBREW LETTER YOD
in my life, this is first time typing copy and paste Hebrew and hope I get it right. if I get it right I will learn HEBREW after retire.
I think billroy is correct it is UTF-8 encode, all I do is see translation table now.
sonnyyu
#10
Jul 04, 2013, 07:58 pm Last Edit: Jul 04, 2013, 08:01 pm by sonnyyu Reason: 1
Quote
Totally disagree, Electronics is very board science, so many vertical field. I found a lot of OP has so deeply knowledge need me multiple lifetimes (I overestimate my skill, at most case I never) to catch. Might be that is your problem treat every one beside yourself as beginner.
AWOL
Quote
Totally disagree
You're allowed to disagree (but I'll reserve the right to disagree with you because it is a forum largely for beginners), but if you carry on posting content-deficient bollocks, and you'll find yourself on the wrong end of a ban.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
sonnyyu
Quote
Totally disagree
"content-deficient bollocks" ?  I am more than happy to find out where?
retrolefty
Well I'm of the opinion that LED life is not an issue to be concerned with in a component like an SSR. I suspect the triac would have a worst MTBF rate then a low current LED.
Lefty
