Topic: problem connecting a ps/2 keyboard with arduino (Read 848 times) previous topic - next topic
abo0ody
Hello
I've been trying to use a ps/2 keyboard with my arduino uno to get keyboard input. I downloaded the latest PS2Keyboard library from
http://www.pjrc.com/teensy/arduino_libraries/PS2Keyboard.zip
and here's the code I'm using
Code: [Select]
#include <PS2Keyboard.h>
const int DataPin = 8;
const int IRQpin =  3;
PS2Keyboard keyboard;
  keyboard.begin(DataPin, IRQpin);
  Serial.println("Keyboard Test:");
  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
    } else if (c == PS2_TAB) {
      Serial.print("[Tab]");
    } else if (c == PS2_ESC) {
      Serial.print("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      Serial.print("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      Serial.print("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      Serial.print("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      Serial.print("[Right]");
    } else if (c == PS2_UPARROW) {
      Serial.print("[Up]");
    } else if (c == PS2_DOWNARROW) {
      Serial.print("[Down]");
    } else if (c == PS2_DELETE) {
      Serial.print("[Del]");
      // otherwise, just print all normal characters
      Serial.print(c);
but it's not working.
is there a problem with the code or is it a problem the wiring I have?
please help.... and thanks for your time
note: I'm not using a ps/2 connector instead i just cut the keyboard's wire and connected the four wires directly to 5v, GND, pin8 and pin3 on the uno.
strykeroz
Since your code is one of the example sketches I expect we can exclude it as the source of the issue.  In your Serial Monitor session is there a chance your baud rate (lower right hand corner of the screen) is selected as something other than 9600?
Cheers !
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
PaulS
Quote
We're to assume from this that you connected the right wire to the right pin?
dylan111111
Hi, just wanting to know if anyone resolved this problem as I am having the same issue. i got a usb keyboard, cut the end off, then connected the red wire to 5v, the black wire to ground, the white wire to pin 8 and the green wire to pin 3. I am using the same code, but it isnt working at all! anymore ideas?
