Topic: Mosfet spec question (Read 807 times) previous topic - next topic
blueventure87
Hi folks!  Hey, I'm new at the Arduino thing like so many before me, I write asking for a hand.  Right now I'm stuck on how to select the proper MOFSET for my first off the books Arduino project.  I want to turn on a string of computer fans.  Each one is 12 volt DC and needs .30 amps  I want to switch on 8 at once via a single MOFSET and leave them running potentially for a day or more at a time.  PWM would be a nice touch but is not part of the initial vision.  This is for a window fan array of 30 fans with 5 "Speeds" done by turning on groups of up to 8 individual fans.
Thanks for the hand!
CrossRoads
8 fans .30A = 2.4A, plus stall current to ovecome at turn on.
http://www.digikey.com/product-detail/en/NTD4963N-35G/NTD4963N-35GOS-ND/2305685
I think these will run nice & cool for you.
Use a 150ohm resistor between arduino pin & gate.
Connec the MOSFET between the fan '-' and Gnd. The fan '+' to 12V.
Put a 1N4001 diode across each fan, cathode to +12 and anode to fan '-'; this lets the motor generated "back emf" dissipate in the motor when you turn off the MOSFET.
larryd
#2
Jul 05, 2013, 09:03 pm Last Edit: Jul 06, 2013, 08:18 pm by LarryD Reason: 1
If you want to learn about them try these:
http://www.electronics-tutorials.ws/transistor/tran_7.html
http://www.youtube.com/watch?v=Te5YYVZiOKs
No technical PMs.
The last thing you did is where you should start looking.
MarkT
Computer fans cannot be simply PWMed since they are entire brushless motor controller circuits - you can
vary the analog supply voltage to vary the speed, and the 4-wire ones allow for digital speed control.  Also they do not exhibit much stall current (they are required not to overheat if they are stalled).
They key thing when choosing a MOSFET is to get a logic-level one - this is essential, and then
to choose one with a low-enough Rds(on) (on-resistance) so that it doesn't overheat - calculate the
dissipation as I-squared-R.  These days there is no excuse not to get a device with Rds(on) below 0.05 ohms.
Do not choose a high-voltage MOSFET for a low-voltage circuit, high voltage devices have much higher Rds(on).
Do not choose a MOSFET from its current rating unless you plan on water-cooling it.
The suggested device above has 0.016 ohm Rds(on) for logic level gate drive, so at 2.4A it will dissipate 92mW,
and thus run pretty cool.
blueventure87
WOW!  Thank you all for your direction.  Quick, precise and usable.  Impressed!
-JK
