Topic: Millis() rover over handling (Read 6175 times) previous topic - next topic
SouthernAtHeart
In this code, will millis() roll over be a problem?  This routine is called to run a motor twice a day all year.  The mills() is only used to check for a stuck door.  If I've got the logic of it figured out, I think if the rollover does occur during this routine, it just won't have the error protection.  That's fine, I just don't want it to be forced into an error if the rollover happens during the routine.
void OpenDoor(){
  digitalWrite(HBRIDGEpower, HIGH);  //power up the H Bridge
  delay(1000);  //give it a chance to stabilize
  digitalWrite(motorOpenPin, HIGH);    //Turn on the motor pin that give the open direction
  unsigned long startMillis = millis(); //create a counter
  while(1){
    if (millis() - startMillis > 30000) DoorError(); //longer than 30 sec means the string is tangled
    if (digitalRead(TopSwitch) == 0) { //Switch is closed
      digitalWrite(motorClosePin, LOW);  //Brake
      digitalWrite(motorOpenPin, LOW);  //Brake
      delay(500); //wait a bit
      digitalWrite(HBRIDGEpower, LOW);  //power down the H Bridge
      break;
    delay(10);
JChristensen
#1
Jul 05, 2013, 09:20 pm Last Edit: Jul 05, 2013, 09:26 pm by Jack Christensen Reason: 1
As long as the interval being timed (30 sec here) is less than the ~50 day millis() rollover interval, and if the comparison is done with subtraction and unsigned variables as it is here (good job!) then the rollover will never be a problem. The code will operate the same even if rollover occurs during the 30 second interval.
SouthernAtHeart
Thanks!
hugo007
I don't agree with this.
There is a possible failure when the rollover occurs.
  while(1){
      break;
    delay(10);
Lets assume startMillis is now 4,294,967,293( near the end of an unsigned long) and then the mills() function return on the if the value of 4 because the rollover had just happened, this "if (millis() - startMillis > 30000) DoorError();" will be false even if the 30 seconds pass.So there is a leak in your code.
I know the probabilities of that happen are very very small but the failure is there.
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
robtillaart
 while(1){
     break;
   delay(10);
don't know how DoorError() is implemented, should it shut down the HBRIDGE and motors?
@hugoPT
as the math is unsigned it will work, you can test it in a small sketch
  unsigned long a = 4,294,967,293;
  unsigned long b = 1000;
  unsigned long c = b - 1;
  Serial.println(c);
void loop(){}
Rob Tillaart
hugo007
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
nickgammon
while(1){
      break;
    delay(10);
There is no problem with rollover, however I can see DoorError being called every 10 mS.
SouthernAtHeart
why?  I don't see it.
SouthernAtHeart
Oh, I see what you're saying.
If DoorError() is called, it shuts the whole system down ending with an endless while{} statement, waiting for the user to fix the problem.
nickgammon
When you just post snippets we have to guess what the rest does. :P
borref
As long as the interval being timed (30 sec here) is less than the ~50 day millis() rollover interval, ...
It will be good for 30 seconds, but not for ~50 days. The maximum interval we can time is half of that (2^32 / 2 - 1 = ~24.86 days).
  32-bit max interval -> ~24.86days
  16-bit max interval -> 32.767 seconds
    8-bit max interval -> 127 milliseconds
Coding Badly
Are you certain?  Are you certain enough to wager?
borref
Certain of what?
My post is addressing whether this quote is true or false:
"As long as the interval being timed (30 sec here) is less than the ~50 day millis() rollover interval, and if the comparison is done with subtraction and unsigned variables as it is here (good job!) then the rollover will never be a problem."
I say yes, but only if interval being timed is less than ~24 days.
Coding Badly
And I say you're wrong.  How would you like to proceed?
borref
If you only care to express your opinion, I have nothing further to add.
If on the other hand, you want to contribute with insight or knowledge this is my take:
The difference between two unsigned quantities (as in the code discussed above and quoted below) is signed and so the interval is limited to the LONG_MIN ... LONG_MAX range.
