Topic: Proximity Sensor (Read 899 times) previous topic - next topic
Yari
Hello.  I am new at using Arduino and microcontrollers.  I have an application that uses an inductive proximity sensor with pnp output, 24vdc.  Is there a way that I can use this with an UNO?  I keep reading that we are never to go over the 5V.  Is there a signal conditionning circuit that I can put together to help me out?
Thanks,
Yari.
johnwasser
The load of a digital input is low so a resistor voltage divider should work.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
Yari
Thank you johnwasser.
I just want to be sure that I understand.  I will have a Uno powered with 5VDC like usual.  I will have a KS0108 by Adafruit to display the RPM.  The PNP sensor is already on a machine but will be used to count the teeth on a gear so that we can get the RPM.  There are 3 wires, Brown (10-30VDC), Blue (0V) and Black (Signal wire).  Just to make sure I remember a little of my electronics, are you suggesting that I plug the Black wire to a voltage divider in the following manner?
I would have 10VDC power my sensor, put two 1/4Watt 470 ohm resistors in series, connect my black signal wire to the first resistor and ground to the bottom of the second and get a junction wire in between the two resistors with which to connect to the input pin on the Uno?
Thanks again for the help.
johnwasser
Yes, that's what I envisioned.
