Topic: Arduino UNO R3 and OS X 10.8.4 - Uploading Problem (Read 937 times) previous topic - next topic
peterpixel
Like some other people, I haven been able to upload my sketches to my Arduino UNO R3.
I have done a bunch of tests already:
1: The board shows up in my network preferences and my system profile:
2: I have the correct board selected in Arduino: (Arduino UNO); I also tried the Arduino Duemilanove setting.
3: I have tried other R3's, same issue.
4: I have tried other USB cables. Problem not sovled.
5: Board, cable and uploading works perfectly under OS X 10.6.8
When I try to upload, I get the following error:
Code: [Select]
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/peterpixel/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbmodemfa131
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude done.  Thank you.
Is there anyone out there that is able to point me in the right direction?
olaznog10
Hello peterpixel,
I have the same problem, did you find a solution?
In my case I found a weird one (partial solution) which is to plug the arduino to a hub (apple long keyboard with usb plug). In that way is possible to upload you code but when you use 5v energy as normal is automatically disconnected.
I hope you find a better solution.
Regards.
flurin
#2
Aug 01, 2013, 04:23 pm Last Edit: Aug 01, 2013, 04:26 pm by flurin Reason: 1
I had a similar issue with an Arduino Mega 2560 r3:
Code: [Select]
avrdude: stk500v2_ReceiveMessage(): timeout
I had to burn the bootloader again using an AVR-ISP-Programmer.
