Topic: A 6 DOF robotic arm as a CNC machine? (Read 3563 times) previous topic - next topic
RaiRaiRai
I have always dreamed of cheap 5 axle CNC machining mill. It should be possible to CNC-machine a car with that or similar complex object like a human head.
Once I am good to make excellent modelings with Rhinoceros I would like realize these modelings too in real life.
But is there any sense to buy a low cost 6 DOF robotic arm from ebay and use it as a tool like this:
http://www.ebay.com/itm/New-6-DOF-Manipulator-Aluminum-Robot-Arm-Kits-for-Smart-Car-Base-/160998716216?pt=LH_DefaultDomain_0&hash=item257c457338
Is it really difficult to program arduino make whatever form from .stl files in order to CNC machine them with this kind of robotic arm?
Maybe the table where the machinable object is fixed could have such an function that it could rotate with a servo. But I think that in theory a robotic arm with a
table like this should be able to machine whatever form.
Please tell me your opinions of a plan like this. Many thanks in advance.
RaiRaiRai
I found a machining open source software like this for Linux...
http://www.linuxcnc.org/
It probably helps in this issue.
zoomkat
Quote
No.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
aarondc
Not enough:
accuracy
torque
range
with that price point.
You could probably do it for around ~$15,000+, looking at the prices of appropriate DOF welding robots on ebay.
3D-innotech
"Not enough:accuracy,torque,range"
HI
All i need is exactlly that cheap a$$ robot arm with low accuracy with a small motor with 1 foot range
as RaiRaiRai asked a while ago
"Is it really difficult to program arduino make whatever form from .stl files in order to CNC machine them with this kind of robotic arm?"
please advise & help
PaulS
Quote
Then go for it.
Quote
Do you know what an stl file looks like? It's a collection of triangles, each of which has a normal. What, exactly, would you want to do with it?
You could import an stl file into a CAM system, and generate tool paths, and export that data as M and G codes, and then write a program to send those codes to the Arduino.
However, the Arduino makes a pretty lousy reverse kinematics solver, so it will take a while to get the necessary joint angles to move the servos to, to get the end-effector in the proper place/orientation.
