Topic: Ethernet library reference change #2 (Read 2784 times) previous topic - next topic
SurferTim
Jul 06, 2013, 02:27 pm Last Edit: Jul 06, 2013, 02:41 pm by SurferTim Reason: 1
As long as you are in the ethernet library reference, the following pages need an addition.
http://arduino.cc/en/Reference/ClientWrite
http://arduino.cc/en/Reference/ServerWrite
The pages are missing one of the most useful functions if you plan on sending any NULL (zero) bytes.
client.write(dataString,count);
server.write(dataString,count);
Parameters
dataString: the array to write (byte or char array pointer)
count: the number of bytes of the dataString array to write (int)
edit: Corrected dataString parameter to "byte or char array pointer".
SurferTim
#1
Jul 10, 2013, 01:00 pm Last Edit: Jul 10, 2013, 01:46 pm by SurferTim Reason: 1
Bump. Did you have a nice nap?
edit: Here is the library code (declarations) from EthernetClient.h
Code: [Select]
 virtual size_t write(uint8_t);
 virtual size_t write(const uint8_t *buf, size_t size);
Here is the code from EthernetClient.cpp
Code: [Select]
size_t EthernetClient::write(uint8_t b) {
 return write(&b, 1);
size_t EthernetClient::write(const uint8_t *buf, size_t size) {
 if (_sock == MAX_SOCK_NUM) {
   setWriteError();
   return 0;
 if (!send(_sock, buf, size)) {
   setWriteError();
   return 0;
 return size;
Federico_Vanzati
Hi SurferTim,
I've edited the Client and Server write() pages, thanks for the suggestion and for noticing.
I preferred to keep the explanation close to the one given to Serial write() documentation.
Hope you like it.
F
SurferTim
That looks good to me!  :)
One down, two to go!
Federico_Vanzati
One.  :)
DNS fixed. Only the UDP.stop() to go
F
