Topic: New Product: Audio Hacker shield (Read 4880 times) previous topic - next topic
mkrumpus
nootropic design is very happy to announce the Audio Hacker shield!  The Audio Hacker allows you to perform realtime digital signal processing: record audio samples into memory and play them back. Mix samples, manipulate audio, build audio effects, or synthesize entirely new sounds.
It has 256K of serial SRAM, a 12-bit ADC, and 12-bit DAC.  All the product details are at http://nootropicdesign.com/audiohacker
The Audio Hacker library makes it easy to build your own projects and comes with great examples: http://nootropicdesign.com/audiohacker/projects.html
The optional DJ Shield gives you 5 buttons and 3 pots to use for your audio projects:
robtillaart
#1
Jul 06, 2013, 08:17 pm Last Edit: Jul 06, 2013, 08:22 pm by robtillaart Reason: 1
interesting!
Could it be used as a 12 bit oscilloscope (with sample memory)?
Is it easy to get the data from the shield to the Arduino and back?
-- edit--
it would be cool if the gain could be controlled from Arduino (I2C digital pot meter?)
+ bookmarked
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
mkrumpus
Quote
interesting!
Interesting idea, yes.  The sample rate would be limited to around 30 kHz I think.
Quote
Yeah, just normal serial communication.  The library API makes it easy to read from the SRAM chips into a buffer.
Quote
The incoming data can also be modified to apply a gain programatically.  Your code has complete control over the data.  The main constraint is the time required to do a floating point operation (over 300 clock cycles on an int), but it can be done if the sample rate is low enough.
robtillaart
Quote
not too bad
Quote
if the float is a constant there might be some tricks to speed it up. E.g. multiply by PI
Code: [Select]
uint32_t mulPI(uint32_t in)
  // -1,0,3,6,11,12,13,14,15,16,18,19,21,23
  // 11,12,13,14,15,16, == +10 -16
  uint32_t q = (in<<1) + in + (in>>3) + (in>>6) + ((in>>2) - (in>>8))>>8;
  return q;
see also - http://forum.arduino.cc/index.php?topic=172635.0 - and -  http://forum.arduino.cc/index.php?topic=167414.0 - if you are interested in optimizing
Rob Tillaart
czak
Hi, I think Audio Hacker is a great project and I appreciate you providing your designs on the website.
I have a question: in an audio project I'm building I'm aiming to store up to 1 minute of decent quality sound (12bit 22kHz is decent). Do you have experience with larger memory ICs? Are there any which could work in place of the SRAM chips on Audio Hacker?
I've been looking into AT45DB series. Do you have any experience with those?
mkrumpus
@czak,
Thx for your compliments.  I'm not familiar with the AT45DB flash chips.  I wonder how fast they'd be, as speed is critical for decent sampling rates.
earx
cool, excellent, that stackable design!
