Topic: I cant upload anything to my clone arduino nano 328 (Read 2283 times) previous topic - next topic
meybivi
Jul 06, 2013, 11:42 pm Last Edit: Jul 06, 2013, 11:45 pm by meybivi Reason: 1
Hi everyone, I have a clone arduino nano which has ATmega328 micro controller.
My problem is, I cant upload anything via usb port to my arduino. I used my other arduino uno as ISP and I successfully uploaded something via arduino uno to my clone nano. Also I successfully done some serial communication test (I couldn't find it now) with my clone nano. The test is basically to send some data via usb serial port and read the data back from the card which has been sent before.
So the card and usb serial port works but when I try to upload something, arduino software compiles the application but it keeps waiting uploading section forever. When I try to upload application using programmer (by holding shift then clicking the upload button) I get this error;
avrdude: usbdev_open(): did not find any USB device "usb"
I selected the right com port and board also.
Thanks!
larryd
Is clone design or modified to use the DTR auto reset?
No technical PMs.
The last thing you did is where you should start looking.
meybivi
What is DTR auto reset, I add a picture of my card
http://imgim.com/an87863.jpg
Looks like this.
"Is clone design or modified to use the DTR auto reset?"
larryd
DTR reset, resets the controller thus enabling the bootloader (which is responsible to load your compiled sketch).
Try this to see if the manual method works with your clone.
1. Before pressing Upload (in the IDE).
2. Hold down the Reset switch (on the clone).
3. Press Upload (in the IDE).
4. Release the Reset switch when the IDE displays Uploading.
No technical PMs.
meybivi
I did it and this is the result  :smiley-fat:
Binary sketch size: 2.772 bytes (of a 30.720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
larryd
Quote
I don't know if this over-wrote your bootloader, if it did you can burn the bootloader then try the manual method suggested.
Perhaps others can suggest a fix.
No technical PMs.
meybivi
Quote
I have tried before, I guess I won't be able to solve this problem. I will keep using my uno as ISP. We better to be careful about what we buy. That nano was 5 dollars  :)
