Topic: 4pin debug header (Read 913 times) previous topic - next topic
newhobby
What kind of debugger can I use on that 4pin debug header?
Would it only work on AVR Studio?
Thanks,
RI
AmbiLobe
I have not studied this Due debug facility, but it appears to be compatible with the JTAG standard Joint Test Access Group. The four pins would be used according to publicly available documentation for JTAG. A "Boundary Scan" should be accessible which consists of a shift register of vast proportions. You can shift out all states represented on latches in a chain of latches. the Boundary Scan is common on a microprocessor. You also may have access to the internal scan chain in the CPU core. That also is a second chain of flip flops in a chain with thousands of bit states representing proprietary and public microprocessor flags and state info.
I am going to get going.
bobcousins
Thanks,
RI
Its a JTAG/SWD header, a common 0.1" connector although an unusual form factor for JTAG. I use the 10 pin JTAG/SWD header.
You'll need a suitable JTAG/SWD adapter, the Segger Jlink EDU version is fairly cheap and works with many IDE's including Atmel Studio. There are several other ways to do it, it is a question of selecting an adapter supported by your IDE, or vice versa.
Please don't PM me asking for help. Ask questions in the forum.
Ynicky
I use Keil and CooCox CoLinkEx hardware debugging adapter with homemade cable:
http://arduino.ru/forum/programmirovanie/arduino-due-keil
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
