Topic: Please help with debugging... (Read 2324 times) previous topic - next topic
RaiRaiRai
I am trying to combine two sketches:
1. Arduino shift out tutorial: http://arduino.cc/en/Tutorial/ShiftOut
2. Arduino keypad 4x4 tutorial: http://learning.grobotronics.com/arduino-keypad-4x4-en.html
It gives few error messages which are a mystery to me, like:
sketch_jul07a:55: error: expected unqualified-id before 'if'
sketch_jul07a:56: error: expected unqualified-id before '{' token
Please help me to debug this...thanks in advance.
Code: [Select]
#include <Keypad.h>
  Shift Register Example
for two 74HC595 shift registers
This sketch turns on each of the LEDs attached to two 74HC595 shift registers,
in sequence from output 0 to output 15.
Hardware:
* 2 74HC595 shift register attached to pins 2, 3, and 4 of the Arduino,
as detailed below.
* LEDs attached to each of the outputs of the shift register
Created 22 May 2009
Modified 23 Mar 2010
by Tom Igoe
//Pin connected to latch pin (ST_CP) of 74HC595
const int latchPin = 8;
//Pin connected to clock pin (SH_CP) of 74HC595
const int clockPin = 12;
////Pin connected to Data in (DS) of 74HC595
const int dataPin = 11;
char inputString[2];
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] =
  {{'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
byte rowPins[ROWS] = {2,3,4,5}; //connect to row pinouts
byte colPins[COLS] = {6,7,8,9}; //connect to column pinouts
int count=0;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
Serial.begin(9600);}
void loop();
  char key = keypad.getKey();
if (key != NO_KEY);
  Serial.print(key);
count++;
   if (count==250)
      count=0;
// iterate over the 16 outputs of the two shift registers
  for (int thisLed = 0; thisLed < 16; thisLed++) {
    // write data to the shift registers:
    registerWrite(thisLed, HIGH);
    // if this is not the first LED, turn off the previous LED:
    if (thisLed > 0) {
      registerWrite(thisLed - 1, LOW);
    // if this is  the first LED, turn off the highest LED:
    else {
      registerWrite(15, LOW);
  delay(key);
// This method sends bits to the shift registers:
  // the bits you want to send. Use an unsigned int,
  // so you can use all 16 bits:
  unsigned int bitsToSend = 0;
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // turn on the next highest bit in bitsToSend:
  bitWrite(bitsToSend, whichPin, whichState);
  // break the bits into two bytes, one for
  // the first register and one for the second:
  byte registerOne = highByte(bitsToSend);
  byte registerTwo = lowByte(bitsToSend);
  // shift the bytes out:
  shiftOut(dataPin, clockPin, MSBFIRST, registerTwo);
  shiftOut(dataPin, clockPin, MSBFIRST, registerOne);
  // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
AmbiLobe
Syntax error
void loop();
syntax style needed
  unsigned int modulus = slow_speed;     // it determines how often
delete ;
add {
UKHeliBob
The error that you quote is caused by the semicolon at the end of this line
Code: [Select]
if (key != NO_KEY);
Remove that and the error will go away.  Unfortunately there are other errors in the code, including (yet) another spurious semicolon at the end of this line
Code: [Select]
void loop();and the fact that the loop() function does not have an opening brace.
Fix those and there are still problems though.  Can you explain what the program is supposed to do ?  The shift register portion of the program seems to have no connection with the keypad portion, and several function and variable declarations are missing.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
RaiRaiRai
Hello!
Many thanks for your tips. However there is still something deeply wrong with my coding.
I expect this program to blink the knight rider lights according to rhythm which I set with a keypad. For example when the light are blinking with  a knight rider style I may press from the keypad with the numbers "123" and the delay between the blinking lights will be 123 milliseconds. However today I received a lcd screen for the Arduino and I would like to add a visual feedback for the user. But thats another story, lets try to make this code work as is before making things truly complex.
The code is now like this and it gives the following errors:
sketch_jul07a:68: error: expected unqualified-id before 'for'
sketch_jul07a:68: error: expected constructor, destructor, or type conversion before '<' token
sketch_jul07a:68: error: expected constructor, destructor, or type conversion before '++' token
Code: [Select]
#include <Keypad.h>
Hardware:
as detailed below.
Created 22 May 2009
by Tom Igoe
  {{'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
int count=0;
void setup(){
if (key != NO_KEY);
  Serial.print(key);
count++;
   if (count==250)
      count=0;
    if (thisLed > 0) {
    else {
  delay(key);
Arrch
#4
Jul 09, 2013, 12:13 am Last Edit: Jul 09, 2013, 03:59 am by Arrch Reason: 1
Code: [Select]
if (key != NO_KEY);
 Serial.print(key);
count++;
  if (count==250)
     count=0;
Rarely is it a good idea to put a semicolon at the end of an if statement. Also, count the number of the left braces versus the number of right braces.
RaiRaiRai
Hello again,
Please be specific cos I am rather new to Arduino coding. I hope somebody can help me with this...
Anyway the compiler now gives the following errors:
sketch_jul07a:66: error: expected unqualified-id before 'for'
sketch_jul07a:66: error: expected constructor, destructor, or type conversion before '++' token
With the following code:
Code: [Select]
#include <Keypad.h>
Hardware:
as detailed below.
Created 22 May 2009
by Tom Igoe
  {{'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
int count=0;
void setup(){
void loop(){
if (key != NO_KEY)
  Serial.print(key);
count++;
   if (count==250)
      count=0;
  for (int thisLed = 0 thisLed < 16; thisLed++) {
    if (thisLed > 0) {
    else {
  delay(key);
larryd
Quote
Line 66 has an ERROR in it.
Look up how to use  the "for"(.....)  syntax.
No technical PMs.
The last thing you did is where you should start looking.
RaiRaiRai
I really do not understand what is wrong with the line 66...
I do have searched all the tutorials...
larryd
No technical PMs.
holmes4
There is only one way to combine sketches
1. Understand what the first sketch does and why it does it.
2. Understand what the second sketch does and why it does it.
3 Write a new sketch that does what you want!
Mark
RaiRaiRai
Ok. Many thanks Larry D.
Now the compiler complains only one error:
sketch_jul07a:69: error: expected unqualified-id before 'for'
this happens at the line 66...
holmes4. I am asking help in order to combine these two sketches. I think you are very right but I was wishing to get quickly decent results.
As said I am very new to programming so please be patient with me. After all I am learning all the time I think.
larryd
No technical PMs.
PaulS
If you'd put each { on a new line (where they belong) and learn to use Tools + Auto Format, you wouldn't be having half the problems you are having now.
