Topic: IC Fabrication Company... (Read 16700 times) previous topic - next topic
Sandeep_Raj
I am planning to start a IC fabrication business. It is about designing circuits, printing and fabricating them into commercial circuit boards. I need all the machinery and raw materials to make them. Is there somewhere I can get these stuff? Please Suggest
Thankyou
CrossRoads
Are you talking about making the actual chips, packaging the die, etc? Or just mounting components manufactured by others onto PCBs that you may or may not manufacture?
Sandeep_Raj
just mounting components on PCBs. Creating my own circuit design, making commercial pcb and mounting components in them.
aarondc
For surface mount your best bet is pick and place machines.
Sandeep_Raj
Pick and place. Seriously? Dude. I need to print my circuits in pcb. To create my own design and make my own pcb. Pick and place machine? What are you talking about? how will that help. Am a bit serious in here plz.
Thank you
CrossRoads
The pick & place machine is to put the components on the boards, which you said you needed in reply #2.
You would use a program like Eagle from cadsoft.de (cadsoftusa.com) to design the PCB, any of several companies that specialize in making PCBs, than pick & place machine to place the components on the PCB and the re-flow soldering to make the electrical connections.
I get the impression you don't really know what you are getting into here.
Sandeep_Raj
Well. Yea. Basically am a Mba student. My project is to start a business and show growth in it. Am planning to start a pcb design and manufacture unit. I have little Idea on what to do. My plan is not to manufacture ic. It is only to make pcb. I need to manufacture the board where the ic is placed. What all machineries do I need. What all raw materials are required plz let me know.
Sandeep_Raj
I just checked the site which you gave me. I can understand that the circuit is designed using it. The pick and place machine places the components in the board. Please bare my ignorance. How is that design printed in the pcb? How is it done? What machine is used to do that. Please let me know. I greatly appreciate your patience for putting up with me.
Thank you
CrossRoads
Ah, so you've scaled back a bit.
Basically, you will buy 2 sided copper clad fiberglass, perhaps in different thicknesses.
Expose a pattern onto the boards, which determines where copper will remain.
Cure that pattern, then immerse the boards in a solution that removes the unexposed copper.
Remove the material over the remaining copper.
Drill holes to all connections from one side to the other.
"Plate" the holes to connect the 2 sides.
Apply a solder mask to prevent solder from shorting between traces and other traces, or copper planes.
Apply/print any labelling.
QA control all along the way, including electrical test for continuity and not shorts.
Cut the boards to shape.
Package.
Ship.
Online ordering.
Payment processing.
Website/Marketing.
This site goes thru the steps in more detailn for how a board is made, with videos too.  You can find other similar data online.
http://www.eurocircuits.com/index.php/making-a-pcb-eductional-movies
As to what the actual machines used are along each step, now that you know what to look for, you can search for them online.
Different machines can do different maximum size boards, and I imagine different machines are needed for a simple 2 layer board vs a 4-6-8-12-14-16 layer board, the larger ones used for computer boards and backplanes, often with blind and buried vias (vias that connect internally but do not go thru all layers).
CrossRoads
aarondc
is this just for an assignment for your MBA course?
aarondc
if on the other hand you are serious, what is your target market?
Sandeep_Raj
It is not just for my mba course. I actually am serious about it. At initial stages my target market would be students of all age group.
aarondc
I am curious why an MBA student seeks information on what is required to fabricate PCBs for their business before doing market analysis on whether the business is viable. Particularly given you have no experience in the field of an established market with well-known players, miniscule margins and a certain level of fabrication quality required that would involve (IMO) large capital start up costs. (Compared to say, Apple, who essentially created the home PC market, or Microsoft, who created the home OS market).
Not to mention lack of repeat business and the inherent low-income (cliche?) exhibited by student populations, where disposable income seems to be directed towards entertainment.
I don't see 8 year old students paying for custom PCB manufacture either. In fact uni-level would be the most likely, if any.
I am also curious what sort of students would rather have someone make their PCBs for them (where the driver would be course related, surely), rather than make them themselves.
Can I ask why you have chosen custom PCB manufacture as your business? Have you ever done anything in the electronics field?
aarondc
Brilliant link, thank you.
