Topic: Washable crystal (Read 5259 times) previous topic - next topic
SouthernAtHeart
Is there such a thing as a washable crystal?  I like to give my board a good hot soapy bath after soldering all the washable components on, and would like to use more components that are washable. I've always assumed SMD crystals are not washable. I use this one:
http://www.digikey.com/product-detail/en/ECS-160-20-3X-TR/XC1776CT-ND/2676640
The data sheet says nothing about washable. Anyone know much about crystals and/or of a washable type?
Osgeld
#1
Jul 08, 2013, 03:19 am Last Edit: Jul 08, 2013, 03:21 am by Osgeld Reason: 1
I dont think any electronics is really washable, you risk shorting out due to water being held under parts and not exposed to air holding in there for long periods of time due to capillary action.
as far as washing flux off, a 99% alcohol bath does nicely and dries out super quick, otherwise use whatever and wait a couple weeks while hoping something doesn't short
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
mrburnette
#2
Jul 08, 2013, 04:51 am Last Edit: Jul 08, 2013, 04:57 am by mrburnette Reason: 1
@SouthernAtHeart:
In the Ol' days before everyone was concerned about ozone holes and global warning, we used a mix of alcohol and a fluorocarbon ... Today, some commercial products are similar but substitute to remain on the right side of Federal law:
http://www.zorotools.com/g/00060945/k-G0897163
You may experiment with other commercial products with large alcohol contents:
http://www.splashwash.com/Product.aspx?pid=9
Be aware, the evaporating alcohol will likely cause moisture condensation.
I read that an American supplier of Arduino breakout boards uses reflow soldering and then does bathe the boards... But then they put them in a low humidity controlled dryer for a timed period.
https://learn.sparkfun.com/tutorials/electronics-assembly/all
( see Washing - select from left pane menu)
I have made circuit boards for over 40 years and have never given my boards a water bath... But if you feel you must you should at least build or concoct some type of low humidity dryer.
- Ray
JChristensen
I've used tetrachloroethylene (brake cleaner) and it works well but is pretty pungent stuff. Denatured ethanol (in gallon cans in the paint department of your favorite big-box home improvement store) seems to work just as well and is not as noxious but as noted above there is usually some minor condensation. I use compressed air to dry the tetrachloroethylene or ethanol. I've also used a blow dryer with the ethanol as it helps deal with the condensation.
I know that a lot of the no-clean fluxes are said to be water soluble but for whatever reason I've never actually considered using water. OTOH, it would seem that anything that stands up to alcohol or tetrachloroethylene would be OK with water. Probably distilled or deionized water would be best.
I haven't used an SMT crystal like that, but it looks like the basic package is pretty similar to the typical through-hole types. Those look pretty well sealed up and I've never had a problem with them.
cmiyc
Well since practically all SMT components are compatible with some form of wash solution, I'm not sure of the problem.
I guess the first order question is, what is it you wash YOUR boards with that damages components?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
SouthernAtHeart
I use hot water and soap. I used to use household alcohol, but it seemed to 'dull' the board --take away the nice shine. I use a flux that is 'water soluable'. I could see parts like the atmega328P-AU, 0803 CAps & Resistors, being unaffected by dipping in hot water but it seemed to me the crystal package would seep liquid into it?  Maybe not??
De-ionized water- will that clean the flux off good?  No soap?  Is that the same as distilled water or is it hard to come by?
cjdelphi
I knew someone who used hot water and soap and just let them dry out before use...
As for the crystal, surely it has to be sealed air tight?... -  I suppose you could always stick the board (after leaving it to dry) in an oven on a low setting
just to make sure there's absolutely no trace of water left, or even a heat gun, hair dryer?
Docedison
I've water washed boards for years.. It depends on the board and how it was assembled. Low clean no clean and water clean fluxes are both water soluble and hygroscopic to some extent, Some worse than others. All components are "Generally" watertight the notable differences being sensors. A crystal or resonator must be watertight in order to avoid the influence of the flux used in soldering the board and the board cleanup later or be susceptible to changes in frequency because of foreign material buildup.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
Osgeld
#8
Jul 08, 2013, 07:49 am Last Edit: Jul 08, 2013, 07:54 am by Osgeld Reason: 1
so you say a SMT compent will be fine overnight in warm tap water with dish detergent then powered on cause the component is sealed?
btw if you are interested I have a 1 in 20 odds on some random amount of money, just spend all your production cost for the next month on that gamble, it should be fine
hint, who gives a crap if the part is sealed! its the leads that screw you up
my dell laptop at work got the roof leaked on, poured nearly 2 cups of water poured out of it, took nearly a month in the dry chamber, hard disk died just about one year later due to detergent growth, thing looks like a salt mine.
so sure go wash your boards in a dishwasher, it only took a year for rain water to kill my laptop, good luck
larryd
Side issue:
You have to be careful with POTs and sockets (all things mechanical).
The washing can deposit flux into the mechanism and cause problems.
Some compressed air helps remove wash from under components.
I always install and solder POTs & sockets after I wash the board.
Flux can then be removed with Q-Tips & liquid.
The SMD crystal will be OK to wash.
No technical PMs.
The last thing you did is where you should start looking.
mrburnette
Quote
CAVEAT: alcohols and petroleum distillates are combustible so if the fan motor in the dryer has brushes ... well, just be aware.  The other issue is that some of the fancy dryers of today have Ion generation, so one could get a spark or statically damage sensitive electronics although it is unlikely once they are in-circuit; but use caution.
- Ray
pwillard
When I was young, (Ok eons ago), I worked as a Wave Solder machine operator.  We used a solvent called 1,1,1-Trichloroethane to clean the boards after soldering and the parts would spend a few minutes completely engulfed in a cloud of the stuff while excess flux would drip off by itself.  Boards would emerge clear of all flux and residues.  Those perfect days are gone now that it was determined that chemicals like this (chlorofluorocarbons) effect the ozone layer.
Since that time, it is quite common to see Aqueous Cleaners in use at board shops.  Where I worked, we adopted a new line with water soluble flux and other water-soluble products while we tested out the washing machine and determined that it OK for the prototype shop that was building and testing the DEC PDP-11/23.
JChristensen
Quote
- Ray
Right, am aware. I give the boards a good shake and use the dryer away from the major concentrations of alcohol. I figured that what was left on the board wouldn't be too large a problem even if it did catch fire  ;)
Was not aware of the ion generation dryers, thanks. Mine is ancient so shouldn't be a problem. This might explain all the bad-hair days though   :D
SouthernAtHeart
Thanks for all the feedback. I like the denatured ethanol idea and might give it a try. With a good drying from an old hair dryer.
MarkT
I hope you do that outdoors in the shade - ethanol flames are practically invisible in daylight and a
blow-dryer can occasionally generate sparks from bit of crud that hit the heating wires.
