Topic: [SOLVED] SPI communication failure... anything obvious with the code? (Read 5721 times) previous topic - next topic
Constantin
Jul 08, 2013, 06:54 am Last Edit: Jul 29, 2013, 01:48 pm by Constantin Reason: 1
Hi everyone,
I am currently trying to get my Teensy 3 and a MCP3911 to communicate via SPI (code below). Unfortunately, I am getting nowhere. Instead of getting the desired response (i.e. an acknowledgement that the right register (0x0D) has been modified to put the ADCs into reset mode), I get nothing but the following:.
Command Register Received: 1101 - Command Received: 11000000
Write Command Byte Sent: 11010
Read Command Byte Used: 11011
Error for register: 1101 - Command Sent: 11000000 - Response Received: 0
Other registers have responded with nothing but 1's.
For those of you well versed in the art of SPI, is there something obvious that I have missed? The bare electrical connections appear to be good, so I feel like I am running out of options... Any help is appreciated and thanks in advance. Constantin
#include "SPI.h"
const uint8_t MCP3911_CS = 9; // Teensy SPI CS1 = MCP3911
const uint8_t SD_Card_CS = 10; // Teensy CS0 = SD Card
const uint8_t MCP3911_DR = 2; //Data Ready Signal for MCP3911
const uint8_t LED = 13; //LED on Teensy
 //SPI Bus setup
 pinMode (MCP3911_CS, OUTPUT); // MCP3911
 pinMode (SD_Card_CS, OUTPUT); // SD Card
 pinMode (MCP3911_DR, INPUT); //Data Ready Pin on MCP3911
 SPI.setBitOrder(MSBFIRST);
 SPI.setDataMode(SPI_MODE0);
 SPI.setClockDivider(SPI_CLOCK_DIV8); //i.e. 6MHz on a Teensy running at 48MHz.
 SPI.begin();
 //Setup Serial Comms
 pinMode(LED,OUTPUT);  //enable blinking LED
 bool led=1;
 for (int i=0;i<2;i++) {
   digitalWrite(LED,led);
   delay(250);
   led = !led;
 Reset_ADC(); //Setup the MCP3911
uint8_t Write_MCP3911_Register (uint8_t MCP3911_Register_Address, uint8_t Command) {
 Serial.print("Command Register Received: ");
 Serial.print(MCP3911_Register_Address,BIN);
 Serial.print(" - Command Received: ");
 Serial.println(Command,BIN);
 MCP3911_Register_Address = (MCP3911_Register_Address<<1) & B00111110;
 //right shift address one digit
 // and ensure last digit is a zero for write command
 digitalWrite(MCP3911_CS, LOW);
 SPI.transfer(MCP3911_Register_Address); // send address with write command to MCP3911
 SPI.transfer(Command); //now send payload
 digitalWrite(MCP3911_CS, HIGH); // deselect the CS pin.
 Serial.print("Write Command Byte Sent: ");
 Serial.println(MCP3911_Register_Address,BIN); // verify what command was sent (i.e. address and write bit = 0)
 //Now Verify all went well
 MCP3911_Register_Address += 1; //Turn on Read Operation by toggling last bit on
 Serial.print(" Read Command Byte Used: ");
 Serial.print(MCP3911_Register_Address,BIN); //show command used
 digitalWrite(MCP3911_CS, LOW); //take CS low to initiate SPI
 SPI.transfer(MCP3911_Register_Address); // send address with read command to MCP3911
 uint8_t Response = SPI.transfer(0x0); //read one response
 digitalWrite(MCP3911_CS, HIGH); //take CS pin back high again to end SPI transmission
 //now verify that the register content matches the command sent. If so, have the function return value of one,
 //otherwise, alert the user that something is amiss.
 if (Response == Command)  return 1;
  Serial.println("");
  Serial.print("Error for register: ");
   Serial.print(MCP3911_Register_Address>>1,BIN);
   Serial.print(" - Command Sent: ");
   Serial.print(Command,BIN);
   Serial.print(" - Response Received: ");
   Serial.println(Response,BIN);
   Serial.println("");
   return 0;
uint8_t Read_MCP3911_Register (uint8_t MCP3911_Register_Address) {
 Serial.print("Desired Register Address: ");
 MCP3911_Register_Address = (MCP3911_Register_Address<<1) & B00111110; //right shift address one digit and mask first two bits and last
 MCP3911_Register_Address +=1; // add one to toggle read bit
 Serial.print(" - Read Command Sent: ");
 return Response;
void Reset_ADC()
// Puts ADC into Reset Mode, i.e. stops ADC conversions until setup is complete.
  bit 7:6 RESET<1:0>: Reset mode setting for ADCs
  11 = Both CH0 and CH1 ADC are in reset mode
  10 = CH1 ADC in reset mode
  01 = CH0 ADC in reset mode
  *00 = Neither ADC in reset mode(default)
  bit5:4 SHUTDOWN<1:0>: Shutdown mode setting for ADCs
  11 = Both CH0 and CH1 ADC in Shutdown
  10 = CH1 ADC in Shutdown
  01 = CH0 ADC in Shutdown
  *00 = Neither Channel in Shutdown(default)
  bit 3: Not implemented, read as 0
  bit 2: VREFEXT Internal Voltage Reference Shutdown Control
  1 = Internal Voltage Reference Disabled
  *0 = Internal Voltage Reference Enabled (Default)
  bit 1: CLKEXT Internal Clock selection bits
  1 = External clock drive by MCU on OSC1 pin (crystal oscillator disabled, no internal power consumption) (Default)
  *0 = Crystal oscillator is enabled. A crystal must be placed between OSC1 and OSC2 pins.
  bit 0: Not implemented, read as 0
 Write_MCP3911_Register (0x0D, B11000000);
nickgammon
There is a potential problem in setup, where you do not bring chip select high initially. Try adding this:
  //SPI Bus setup
  digitalWrite (MCP3911_CS, HIGH);    //  <-------------- start chip select high (inactive)
I loaded your code onto my Uno (I don't have the MCP3911 chip) and tried it.
The write:
The read back:
I haven't read the datasheet, but see if that is what you expect.
Constantin
Nick,
Thank you so much for that advice! I added the suggested digitalWrite line but it had no effect - the program keeps looping without any change in behavior.
So unless there is something blindingly obvious, I will shift over to a hardware diagnostic. FWIW, I have a saleae logic 8 on order, as the logic analyzer built into the QuantAsylum mixed scope is just too unintuitive to use for me (I obviously acknowledge that others may love it and find it super easy to work with).
One of the things I will send up to MCP for advice is the use of the clock crystal -maybe I am pushing it - but I didn't think it would have any impact on the SPI interface.
Constantin
#3
Jul 08, 2013, 05:25 pm Last Edit: Jul 08, 2013, 05:56 pm by Constantin Reason: 1
So, rechecked the data sheets on the respective devices and it appears I had MISO and MOSI swapped. Fixed that, but still no go.
Next, I am going to reduce the speed of the external oscillator to see if that is the issue.
FWIW, the datasheet expectations seem to be met per your output. I am trying to modify register 0D (13 decimal). The MCP spec requires the command byte to start with two zeros (unless you use a different version of the chip), followed by the five bits of the register address you want to modify, and then the read/write bit. Thus, in order to construct the write command byte, I start off by left shifting the desired register by one bit (doubling its value) and then applying a mask to turn the LSB to zero.
If you have a look at the bottom of p. 48 on the MCP3911 datasheet, you can see the reset command being illustrated just as I described and exactly like the MOSI output you so graciously created for me. Thank you again for modeling it on your Arduino and confirming the results.
Yet my MC3911 still returns nothing but zeros when I try and read any responses. Argh.
nickgammon
Left shifting by one will make the LSB zero. No mask needed.
Constantin
Thank you!
So it's likely I destroyed the Mcp3911 by using the continuity beeper mode on my fluke 87 DMM. Now I know the current the DMM produces in that mode is high enough to damage the mcp3911.  Also found out that the teensy 3 offers a simple way to put out a 12MHz Osc signal for the mcp3911. So I will use that instead of the crystal to drive the mcp3911.
Live and learn. Thanks again for your help. The code has been updated per your suggestion.
Constantin
#6
Jul 29, 2013, 01:50 pm Last Edit: Jul 29, 2013, 10:49 pm by Constantin Reason: 1
Just a follow-up, once I replaced the MCP3911 with a fresh chip, all was well.
Moral of the story: DO NOT USE THE BEEPER MODE ON A FLUKE DMM TO VERIFY CONNECTIONS ON A POPULATED PCB, IT CAN FRY YOUR CHIPS!
optimistx
Just a follow-up, once I replaced the MCP3911 and replaced it with a fresh chip, all was well.
That moral sounds very important to me. Would that probably apply to multimeters in general when using them to measure resistance between two points in a populated pcb or breadboard?
Constantin
No, apparently, high currents are only produced in "beeper" mode. So, in general a DMM should be safe - but I would limit measurements for resistance to 'off-mode', i.e. an unpowered PCB.
RayWB
Hello all,
I tried to follow your work with the MCP3911 using an Arduino UNO, and communication using your code works,
but unfortunately when i want to read the ADC value from REG 0x00   or REG 0x03 i just get 0XFFFFFF or 0x80
as result.
As it´s a 3.3V device i took care of level shifting (after blowing one converter =( )
@Constantin
May be you can post some more code , i think i just hav a mismatch in one of the registers.
As English is not my mothers language(I´m from Germany) there might also be misunderstanding of the datasheet.
Thanks for your help!!
RayWB
Constantin
Hi Ray,
I am surprised that the code would not work for you. Are you getting the right responses after writing and reading various registers? If you are getting a match between the write and the read then it's pretty likely that there is something else going on like the chip is in reset, the reset pin is not high, etc. So I'd look around the chip electrically and make sure that everything that should have power, has power, that the CLKIN/OSC is happy and in compliance, that there is a good signal going into both ADC channels and so on.
Plus, you may need three reads for each channel read, depending on how you configured the chip (24-bit vs. 16 bit data registers, and so on). The first and second byte may be all zeros because the chip isn't measuring anything but noise. With zero input on the ADC, the 'data' may be limited to just the third byte, i.e. 0x02 and 0x05, respectively.
Cheers, Constantin
RayWB
Hi Constantin,
thank you for response.
communication to adc works , also the adc reacts on changing the input voltage, but the received data make no sense.
i try to read voltage from a bridge and i´m also in adc´s input range.
I´ll post the used code after making it "readable " for everyone...
I´m nearly shure that I took a mistake setting up one ore more of the registers.
cheers Ray
RayWB
Hi Constantin,
that´s the code i use. i separately control mcp3911 Reset pin to do a hard reset and i also use crystal oscillator 4 MHz
so my config register shows a different number.
May be you can take a look at my code or try it in your hardware setup.
Thanks a lot
Ray
#include "SPI.h"
const uint8_t MCP3911_CS = 4 ; // MCP3911 ChipSelectPin
const uint8_t MCP3911_RES = 5; // MCP3911 ResetPin
byte MCP3911_CTRL = 0;
digitalWrite(MCP3911_CS, HIGH); // Chipselect High
pinMode (MCP3911_RES, OUTPUT); // MCP3911 ResetPin
pinMode (SS, OUTPUT); // Uno´s SS Pin
//SPI setup
SPI.setClockDivider(SPI_CLOCK_DIV4); // 4MHz on a Uno running at 16MHz.
SPI.begin();
//Setup Serial Communication
Serial.print(" Hardware RESET ");
digitalWrite(MCP3911_RES, LOW);  // pull ADC Reset LOW
delay(100);                      // wait 100ms
digitalWrite(MCP3911_RES, HIGH);
Write_MCP3911_Register (0x09, B10000000); //Gain and Boost register set:  current *1 , Both channels Gain 1
//delay(2500);
Write_MCP3911_16bitRegister (0x0C, B00111000,B00000000);
/*Config register set
1st byte:
AMCLK=MCLK = 00
OSR = 4096 =111
Dithering off =00
AZ-Freq=0 (default)
2nd byte
Reset=00 Neither ADC in reset (default)
shutdown=00 Neither channel in shutdown(default)
bit3=0
Vrefext=0 (internal)
CLKext=0( crystal)
bit0 =0
// Costantin´s reset function just uses 2nd byte at 0x0d
//delay(2500);
Write_MCP3911_16bitRegister (0x0A, B11011111,B10111000);// i´m not shure how to setup this!!!
//delay(2500);
int32_t adc;
adc=Read_MCP3911_24bit(0x00);
delay(1500);
Serial.print("channel 0: ");
Serial.println(adc);
adc=Read_MCP3911_24bit(0x03);
delay(1500);
Serial.print("channel 1: ");
// ***************  Constantin´s Code*** slightly modified (using controlbyte)
Serial.print("Command Register : ");
Serial.println(MCP3911_Register_Address,HEX);
MCP3911_CTRL=0;
MCP3911_CTRL|= (MCP3911_Register_Address<<1);//left shift address one digit for write command
SPI.transfer(MCP3911_CTRL); // send address with write command to MCP3911
Serial.print("Address Sent: ");
Serial.print(MCP3911_Register_Address,HEX); // verify what command was sent (i.e. address and write bit = 0)
Serial.print(" Command: ");
Serial.println(Command);
MCP3911_CTRL |= 1; //Turn on Read Operation by toggling last bit on
Serial.print(" Read Address sent: ");
Serial.print(MCP3911_CTRL,HEX); //show command used
SPI.transfer(MCP3911_CTRL); // send address with read command to MCP3911
Serial.print(" Response : ");
Serial.println(Response);
Serial.println("");
Serial.print(MCP3911_CTRL>>1,HEX);
Serial.print(Command);
Serial.println("");
return 0;
Serial.print("Register Address: ");
MCP3911_CTRL = 0;
MCP3911_CTRL |= (MCP3911_Register_Address<<1); //left shift address one bit
MCP3911_CTRL |=1; // set read bit
Serial.print(" - Read from : ");
Serial.println(MCP3911_CTRL>>1,HEX);// shift back right to get address
SPI.transfer(MCP3911_CTRL); // send Controlbyte to MCP3911
return Response;
//----writing the 16Bit registers ------------------------------------------------------------------------------
uint16_t Write_MCP3911_16bitRegister (uint8_t MCP3911_Register_Address, uint8_t CommandHigh,uint8_t CommandLow)
Serial.print("selected Register : ");
Serial.print(" - Command: ");
uint16_t commando=0;  //connect two bytes to show one number
commando=CommandHigh;
commando=commando<<8;
commando|=CommandLow;
Serial.println(commando);
MCP3911_CTRL=0;
MCP3911_CTRL = (MCP3911_Register_Address<<1); //left shift address one digit for write command
SPI.transfer(MCP3911_CTRL); // send command byte to MCP3911
SPI.transfer(CommandHigh); //now send High Byte of payload
SPI.transfer(CommandLow);  //now send Low Byte of payload
Serial.print("Command Byte Sent: ");
Serial.print(MCP3911_CTRL,HEX); // verify what command was sent (i.e. address left shifted 1 Bit and write bit = 0)
Serial.print(" , command : ");
Serial.print(" Read Command Byte : ");
Serial.print(MCP3911_Register_Address,HEX); //show command used
SPI.transfer(MCP3911_CTRL); // send control byte(address left shifted 1Bit) with read command to MCP3911
uint8_t ResponseHigh = SPI.transfer(0x0); //read High Byte response
uint8_t ResponseLow = SPI.transfer(0x0);  //read Low Byte response
uint16_t Response2=0;
Response2=ResponseHigh;
Response2=Response2<<8;
Response2|=ResponseLow; //connecting the 2 bytes to one number
Serial.print(" -command Received: ");
Serial.println(Response2);
Serial.println("");
if (Response2 == commando) return 1;
Serial.println("");
Serial.print(commando);
Serial.println("");
return 0;
void Reset_ADC()
//Write_MCP3911_Register (0x0D, B00000000);
int32_t Read_MCP3911_24bit( uint8_t MCP3911_Register_Address)
  uint8_t HB,MB,LB=0;
  int32_t adc0code=0;
MCP3911_CTRL = 0;
MCP3911_CTRL =(MCP3911_Register_Address<<1); //left shift address one digit for write command
HB = SPI.transfer(0x0);//receive High Byte
MB = SPI.transfer(0x0);//receive Middle Byte
LB = SPI.transfer(0x0);//receive Low Byte
adc0code = HB;
adc0code = adc0code<<8;
adc0code |= MB;
adc0code |= LB;         //connecting the 3 bytes to one number
return adc0code;// returning result
zoomkat
I'm surprised Fluke would have a DMM design that would put more current thru a circuit for a continuity beep function (assuming that is the "beep" function) than is used for resistance measurements.
RayWB
got it running now , reason was missing VREF connection, so inputs seemed out of range :smiley-red:
