Topic: voice recognisation kit AND Arduino Uno (Read 947 times) previous topic - next topic
tahmod
I am trying to do this tutorial   .http://www.youtube.com/watch?v=8BjMuE6mdBI
-I am using this guide to get the voice recognisation kit workinghttp://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Shields/EasyVR_User_Manual_3.3.pdf
-I have a arduino uno, and a EasyVR shield not the EasyVR.
-I have tested the voice recognisation with the software VRbot Gui V1.1 and the software was recognizing my voice.
When I put the code in the arduino uno, and run the serial monitor. The first text written is "Trigger" and when I say my trigger word Robot or LED it does not do anything in the serial monitor. It must write reader in the serial monitor but does not.
-Should I retest with putting a LED and a resistor at the pin 12?
-I can make a video if you guyswant to see what I have done so far and maybe spot the problem?
-any guide?
PaulS
Quote
What good would that do? If the commands you are saying now don't do anything, adding another one is not likely to make the others start working. Changing what the code that isn't called does is not likely to make that code get called.
Quote
No. You could post your code, though.
tahmod
The code is here
http://www.kevindarrah.com/download/arduino_code/VR_BOT_pw.pde
and the video code is a bit different. I am using the code in the wbesite.
PaulS
Code: [Select]
int i;
char reader;
NewSoftSerial tx(30,3);// tx on 14
NewSoftSerial rx(2,30);// rx on 12
If you can't get the comments right in the first 4 lines of code, why should I, or anyone else, read beyond that?
Useless comments are just that. Keep them correct or exercise the delete key.
Code: [Select]
rx.begin(9600);
tx.print('b');
Only one instance of NewSoftSerial/SoftwareSerial can be active at once. Since rx was just started, tx is not active. Printing to, or reading from, the non-active version is rather useless.
Why have you not upgraded to a more recent vintage version of the IDE?
tahmod
#4
Jul 27, 2013, 03:29 pm Last Edit: Feb 08, 2014, 07:18 pm by tahmod Reason: 1
The code is correct I changed it but the problem is when I try in the arduino. (I wrote the problem above)
UKHeliBob
Code: [Select]
SoftwareSerial tx(30,3);// tx on 14
SoftwareSerial rx(2,30);// rx on 12
Two instances of SoftwareSerial sharing a pin does not sound like a good idea and I am also intrigued by the comments.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
tahmod
PaulS
Quote
so what I should do?
Fix
the
comments.
Properly
indent
your
code;
put
each
on
a
new
line
and
use
Tools
Auto
Format.
Your code looks pretty dumb displayed that way.
tahmod
#8
Aug 12, 2013, 07:04 pm Last Edit: Feb 08, 2014, 07:18 pm by tahmod Reason: 1
done. What can I do to make the code work in the arduino
codlink
I have significant experience with EasyVR.
First where are you getting your code from?  You should be generating it through the Commander software.  It will automatically format your code.
Where is the jumper set on the Shield?
You should be adhering the suggestions from the other replies here.  Most notable is using CODE tags instead QUOTE tags.  When you paste your code, highlight it, click the # button to insert code tags.
//LiNK
el_supremo
You still aren't posting your code properly. Read this: How to post code properly
Pete
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
