Topic: Coin Acceptor + Arduino UNO R3 - programing issue (Read 3862 times) previous topic - next topic
liby4n
Hello ,
Im new to such thing as electronics , im a photo booth builder
i got the coin acceptor " CH-923 " and i programed it to identify and accept one type of coin " no cash value " and send 1 pulse ..
though i have a major problem with the programing ..
how can i program the arduino to a accept the pulse from the coin acceptor and turn it into a mouse click ? , Just like that !
i'll be grateful , thanks for your help .
PaulS
Quote
That depends on how you have connected the coin acceptor to the Arduino.
Quote
You need the Arduino Mouse board (also known as a Leonardo or Micro).
liby4n
hey , i ordered the Leonardo once you told me to , and it has just arrived ..
what is next ..
PaulS
Quote
what is next ..
You write some code.
And, before you ask, you test the code. Then, you debug the code.
troglodisme
Hey did you manage to write some code? Got stuck with this too..
I never used interrupts before and don't have much time to finish this now.. Any example code?
Thanks!
gorganadrian
hy,
try the next code
Code: [Select]
      This sketch assumes that coin 1, will return 1 pulse, coin 2 will return 2 pulses, and so on.
     Coin values:
     1 = 0.5
     2 = 1
     3 = 2
     4 = 10
    const byte coinValues[4] = {
      5, 10,50, 100}; //Coin values goes into this array
    #define pulseTimeout 200        //How many milliseconds there are from the last impulse to the coin is determined (default 275)
    #define actionTimeout 60000     //How many milliseconds before stored credit is reset (default 60000)
    unsigned long lastAction = 0;   //When last action was made
    unsigned long lastPulse = 0;    //When last pulse was send
    int pulseCount = 0;             //How many pulses we got
    int currentCredit;              //The current credit
    void showCredit()
      int credit = currentCredit/10;
      int left = currentCredit % (currentCredit/10);
      Serial.print("Current credit: ");
      Serial.print(credit, DEC);
      Serial.print(".");
      Serial.print(left, DEC);
      Serial.println("0");
      attachInterrupt(0, acceptorCount, RISING); //Digital interrupt pin 1
      attachInterrupt(1, acceptorPulse, RISING); //Digital interrupt pin 2
      Serial.println("Coin Acceptor ready");
      pulseCount = 0;
      pinMode(13, OUTPUT);
    unsigned long tempAction;
    unsigned long tempPulse;
      tempAction = lastAction;
      tempPulse = lastPulse;
      if (millis() - lastPulse >= pulseTimeout && pulseCount > 0 || pulseCount >= 4)
        if (tempAction != lastAction || tempPulse != lastPulse) return; //Check if interrupt has fired since loop started, wait for next cycle if it has
        tone(12, 1800, 150);
        currentCredit += coinValues[pulseCount-1];
        showCredit();
        pulseCount = 0;
      if ((millis() - lastAction >= actionTimeout) && (lastAction != 0) && (currentCredit > 0) && (pulseCount == 0))
        currentCredit = 0;
        lastAction = 0;
        Serial.println("\n*** TIMEOUT! Credit reset. ***");
        showCredit();
    void acceptorPulse()
      lastAction = millis();
      lastPulse = millis();
      pulseCount++;
    void acceptorCount()
      digitalWrite(13, digitalRead(13));
all credit goes to https://www.youtube.com/watch?v=wLgWcS-utIM
AWOL
Code: [Select]
Coin values:
     1 = 0.5
     2 = 1
     3 = 2
     4 = 10
    const byte coinValues[4] = {  5, 10,50, 100};
Isn't there a mismatch between comment and code there?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
