Topic: VIN Pin on Arduino Due: Sourcing (Read 2041 times) previous topic - next topic
dgelman
How much current can the VIN Pin provide?  Is it regulated?  I cant seem to find out the schematic.
Or is it a straight connection from the barrel jack?
http://arduino.cc/en/uploads/Main/arduino-Due-schematic.pdf
Thanks,
Daniel
Dialup is the future.
graynomad
#1
Jul 10, 2013, 02:20 am Last Edit: Jul 10, 2013, 02:23 am by Graynomad Reason: 1
It's a straight connection to the barrel jack almost, it goes through an inductor but that won't affect you I think.
The jack on on the schematic between the two USB ports.
EDIT: The PCB traces may be a limitation current wise, I've not looked at them.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
retrolefty
_____
Rob
Actually the limit is most likely the series polarity protection diode wired between the power connector's positive contact and the input to the on-board +5vdc voltage divider. That diode has a 1 amp max continuous rated diode as I recall.
Lefty
dgelman
Lefty,
Does this mean that VIN will only source 1A of current? I am developing an Arduino shield for the Due that has 3 motor drivers as well as an xbee module.  I was planning on using the VIN pin, to power the drivers as well as the 5V pin to be regulated down for the XBEE but now I might have some issues.
My motors are 12V 300mA free running. x3 this will draw too much current if VIN only supplies 1A. Looks like I might have to do some external power.
Daniel
