Topic: reading the resistance of different vegetables (Read 970 times) previous topic - next topic
KaOS-bEat
I'm trying to measure the resistance from different fruit/vegetables using a simple voltage divider setup.
I measured different Rveg somewhere between 100K and 800K (from apples to zucchini).
but I cannot seem to stretch the range I read from analogIn to be large enough to be usable.
I tried using different resistors for the other part of the divider, and even pot's so I could adjust the division (this works to some extent)
but I can't seem to figure out what the best solution would be. there is a movie illustrating the problem (with the console outputting values)
eventual goal is a 4 step sequencer driving a modded korg monotron using vegetables as steps, looks like this right now
https://plus.google.com/u/0/104220538357876152457/posts/HC1L3JucEFR
thanks!
K
KaOS-bEat
I've just seen this post (measuring ground moisture) http://forum.arduino.cc/index.php/topic,37975.0.html
this could also work for the vegetables I think. Is this better then a "regular" voltage divider?
tips/advice anyone?
K
