Topic: werid error - No device found (Read 858 times) previous topic - next topic
ralphnev
been working on my second Due for 8 weeks or so
suddenly i started getting No device found on COM5
i tried the Native port  & can program the device -
but the programming port seems to be kaput ..
Due #1 / the nano / & others work fine ...
tried to change to COM10  no effect ..
anybody seen this before?
ralphnev
#1
Jul 16, 2013, 02:04 pm Last Edit: Jul 16, 2013, 04:13 pm by ralphnev Reason: 1
reply to my own post :
pretty sure the ATMEGA16U2 has lost its programming ..
what hardware is needed to reflash it ?
never mind
-- was able to dig up the info / for the record
A) avrdude.exe / avrdude.config is not located where the doc say -- it is in:
    arduino-***/hardware/tools/avr/bin
B) the hexfile is buried pretty deep
    arduino-***/hardware/arduino/sam/firmwares/atmega16u2/Arduino-DUE-usbserial.hex
C) I used a Nano as a AVRISP which has the same pinouts as the UNO descibed in
    http://arduino.cc/en/Hacking/Upgrading16U2Due
D) the Nano would error out ("avrdude: stk500_getsync(): not in sync: resp=0x15") without the required a 120ohm resistor  between Vcc & reset
    http://laclefyoshi.blogspot.ca/2011/01/note-of-caution-for-arduino-isp.html
--- this was all to no avail - my Due still can not be programed via the USB Programming port
to program my Due requires a tenitive connection to the USB native port which resets after every upload (^#&$%&%!!!)
