Topic: Arduino script stops after random period of time (Read 3299 times) previous topic - next topic
Walder
I'm using an accelerometer and magnetometer to take a tilt compensated heading and write it to a micro SD card. I originally tried with a delay of 100 and when the script continued to crash randomly I slowed it down to a delay of 250ms. I am still having the same issue. I am running the system on a Mini Pro 3.3v 8Mhz ATmega328 using an ADXL345 accelerometer and a HMC5883L Magnetometer connected via TWI. The SD card reader/writer is a sparkfun 3.3v version connected via SPI. Here is the code
Code: [Select]
// Reference the I2C Library
#include <Wire.h>
// Reference the HMC5883L Compass Library
#include <HMC5883L.h>
// Reference the ADXL345 Accelerometer Library
#include <ADXL345.h>
// Reference the SD Card Library
#include <SD.h>
// Store our compass as a variable.
HMC5883L compass;
// Store our accelerometer as a variable.
ADXL345 accel;
// Set up a pin we are going to use to indicate our status using an LED.
int runningPin = 2; // I'm using digital pin 2.
int failurePin = 3;
//Create Error variables
int areConnected = 0; // Store our connection status here.
int recordCount = 0;
//Set up the SD card CS on digital pin 10 and open the data file
const int chipSelect = 10;
File dataFile;
  Serial.begin(9600); // Initialize the serial port.
  Wire.begin(); // Start the I2C interface.
  pinMode(runningPin, OUTPUT); // Ready an LED to indicate our status.
  pinMode(failurePin, OUTPUT);
  compass = HMC5883L(); // Construct a new HMC5883 compass.
  accel = ADXL345(); // Construct a new ADXL345 accelerometer.
  compass.EnsureConnected();
  accel.EnsureConnected();
  if(compass.IsConnected && accel.IsConnected)
    areConnected = true;
    Serial.println("Connected to HMC5883L and ADXL345.");
    digitalWrite(runningPin, HIGH);
    digitalWrite(failurePin, LOW);
    areConnected = false;
    digitalWrite(runningPin, LOW);
    digitalWrite(failurePin, HIGH);
    if(compass.IsConnected == 0)
      Serial.println("Could not connect to HMC5883L.");
    if(accel.IsConnected == 0)
      Serial.println("Could not connect to ADXL345.");
if(areConnected)
    compass.SetScale(1.3); // Set the scale of the compass.
    compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous
    accel.SetRange(2, true); // Set the range of the accelerometer to a maximum of 2G.
    accel.EnableMeasurements(); // Tell the accelerometer to start taking measurements.
  Serial.print("Initializing SD card...");
  // **SD** make sure that the default chip select pin is set to output, even if you don't use it:
  pinMode(SS, OUTPUT);
  // **SD** see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  // **SD** Open up the file we're going to log to!
  dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (! dataFile) {
    Serial.println("error opening datalog.txt");
    // Wait forever since we cant write data
    while (1) ;
  if(areConnected)
    MagnetometerScaled magnetometerReadings = compass.ReadScaledAxis();
    AccelerometerScaled accelerometerReadings = accel.ReadScaledAxis();
    float headingNTC = CalculateHeadingNotTiltCompensated(magnetometerReadings);
    float headingTC = CalculateHeadingTiltCompensated(magnetometerReadings, accelerometerReadings);
    // Output the data via the serial port.
    Output(headingNTC, headingTC);
    dataFile.flush();
    delay(250);
float CalculateHeadingTiltCompensated(MagnetometerScaled mag, AccelerometerScaled acc)
  // We are swapping the accelerometers axis as they are opposite to the compass the way we have them mounted.
  // We are swapping the signs axis as they are opposite.
  // Configure this for your setup.
  float accX = -acc.XAxis;
  float accY = -acc.YAxis;
  float rollRadians = asin(accY);
  float pitchRadians = asin(accX);
  // We cannot correct for tilt over 40 degrees with this algorthem, if the board is tilted as such, return 0.
  if(rollRadians > 0.78 || rollRadians < -0.78 || pitchRadians > 0.78 || pitchRadians < -0.78)
    return 0;
  // Some of these are used twice, so rather than computing them twice in the algorithem we precompute them before hand.
  float cosRoll = cos(rollRadians);
  float sinRoll = sin(rollRadians);
  float cosPitch = cos(pitchRadians);
  float sinPitch = sin(pitchRadians);
  // The tilt compensation algorithem.
  float Xh = mag.XAxis * cosPitch + mag.ZAxis * sinPitch;
  float Yh = mag.XAxis * sinRoll * sinPitch + mag.YAxis * cosRoll - mag.ZAxis * sinRoll * cosPitch;
  float heading = atan2(Yh, Xh);
  return heading;
float CalculateHeadingNotTiltCompensated(MagnetometerScaled mag)
   // Calculate heading when the magnetometer is level, then correct for signs of axis.
   float heading = atan2(mag.YAxis, mag.XAxis);
   return heading;
float RadiansToDegrees(float rads)
  // Correct for when signs are reversed.
  if(rads < 0)
    rads += 2*PI;
  // Check for wrap due to addition of declination.
  if(rads > 2*PI)
    rads -= 2*PI;
  // Convert radians to degrees for readability.
  float heading = rads * 180/PI;
  return heading;
void Output(float headingNTC, float headingTC)
  if (recordCount <= 50) {
    recordCount ++;
  }  else {
    recordCount ++;
  if (SD.exists("datalog.txt")) {
  dataFile.print(RadiansToDegrees(headingNTC));
  dataFile.print(", ");
  dataFile.println(RadiansToDegrees(headingTC));
  Serial.print(recordCount);
  Serial.print(", ");
  Serial.print("Heading: ");
  Serial.print(RadiansToDegrees(headingNTC));
  Serial.print(" Heading (Tilt Compensated): ");
  Serial.println(RadiansToDegrees(headingTC));
  Serial.print("Error recording at ");
  Serial.println(recordCount);
  while(1);
wildbill
The libraries you are using are consuming RAM, as are all those serial prints of verbose text and assuming you're using an UNO, you have 2K. Use the F macro to put that text in progmem instead:
Code: [Select]
    Serial.println(F("Connected to HMC5883L and ADXL345."));
Walder
This did not help. Could it be that I'm asking it to perform too much maths, should I simplify the code?
robtillaart
First thing I notice is that there is too much comments in the code to be readable ...
example this line of code is perfectly self documenting. No need to add any comment.
It means less typing for you , less reading for the debuggers. Comments should tell the why (and sometimes the what) but never the how.
Removed lots of unneeded comments -> found 2 places with questions
Code: [Select]
#include <Wire.h>
#include <SD.h>
HMC5883L compass;
ADXL345 accel;
int runningPin = 2;
int failurePin = 3;
File dataFile;
  Wire.begin();
  accel = ADXL345();
  if (compass.IsConnected && accel.IsConnected)
    if (compass.IsConnected == 0)
    if (accel.IsConnected == 0)
  if (areConnected)
    while (1);
  if (! dataFile) {
    while (1) ;
  if (areConnected)
    dataFile.flush();
    delay(250);
  // We cannot correct for tilt over 40 degrees with this algorithm, if the board is tilted as such, return 0.
  if (rollRadians > 0.78 || rollRadians < -0.78 || pitchRadians > 0.78 || pitchRadians < -0.78)
    return 0;  ?? HOW TO DIFFERENTIATE BETWEEN A VALID 0 AND AN ERRONEOUS ZERO
  // precompute vars.
  // tilt compensation algorithm.
  return heading;
   ?? WHERE IS THIS SIGN CORRECTION DONE???
   return heading;
float RadiansToDegrees (float rads)
  // Degrees should be between 0..360
  while (rads < 0) rads += 2*PI;
  while (rads > 2*PI) rads -= 2*PI;
  return heading;
  recordCount++;  // YOU SHOULD UPDATE recordCount TO HAVE MEANINGFUL LOGGING
    recordCount ++;
  }  else {
    recordCount ++;
  // precompute
  float HNTC = RadiansToDegrees(headingNTC)
  float HTC = RadiansToDegrees(headingTC)
  if (SD.exists("datalog.txt"))  // MAKE A RETRY MECHANISM HERE
    dataFile.print(HNTC);
    dataFile.println(HTC);
    Serial.print(", ");
    Serial.print(HNTC);
    Serial.println(HTC);
    // while(1); // <<<<<<<<<<<<<<<<<<<<<<<<<< I would remove this one so it can retry if the disk has one bad read.
your code has 3 places where it has a blocking stop. E.g. if the SD card does make one bad read (Exists), it blocks.
You could rewrite it to have at least 3-5 retries there (log the number of retries! as it can indicate a bad disk.
my 2 cents
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Walder
Thanks for your reply. A very large portion of this ncode comes from www.loveelectronics.co.uk/Tutorials/13/tilt-compensated-compass-arduino-tutorial.
So I cannot speak for the errors in the math. I am very new to Arduino. I have tried to incorporate a retry mecahnism like so
Code: [Select]
  dataFile.print(RadiansToDegrees(HnTC));
  dataFile.println(RadiansToDegrees(HTC));
  delay(250);
  } else if(writeError <= 5) {
    dataFile.print(RadiansToDegrees(HTC));
    dataFile.print(", Write Error #: ");
    writeError ++;
    dataFile.println(writeError);
    delay(250);
    dataFile.flush();
    Serial.print(F("Error recording at "));
Would this work? It is worth mentioning that currently, when the code goes wrong, the failure light does not illuminate only the Arduinos red power LED is lit up, there is no other activity.
Thanks again for your assistance and patience.
robtillaart
something like this ?
Code: [Select]
int retries = 5;
bool done = false;
while (done == false && retries > 0)
  retries--;
    dataFile.flush();
    delay(250);
    done = true;
if (done == false)
Rob Tillaart
MathiasVDA
I happened to experience the same thing with writing a sensor value every 5ms to SRAM (with a GSM shield attached on a arduino mega). In my case I solved it by attaching a 12V battery instead of just the USB cable.
