Topic: 60 Second countdown using a 2 digit Seven second display (Read 4609 times) previous topic - next topic
Silveira89
Hi guys,
so I'm trying to make a 60 second countdown timer using an arduino uno.  i want it to start the countdown when a push button is pushed, and stop at 0 until the push button is hit again.  thus making it start at 60 and count to 0 again.  I literally have no idea how to do this. i found some code counting down from 9 - 0 using a 1 digit seven segment display, but it loops and i have no idea how to adjust it to make it 2 digits and count from 60.  Any ideas or tips would help alot! This is my first time using an arduino! only other microcontroller i programmed was a 8051 and that was assembly code! much different from C code. Thanks for any help that you can provide!!
Henry_Best
Code????????
Schematic????????
Do you think we're mindreaders?
larryd
Show us this code and the schematic that goes with it.
No technical PMs.
The last thing you did is where you should start looking.
marco_c
I have some code on my repository (link below) for a countdown timer that may be useful for you.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
fungus
Do you have any interest in knowing or do you just want a gadget? Learning to do it will require a lot of time (but you'll be able to do other things as well as timers).
Silveira89
I havent really started coding it yet.  its my first time using an arduino so im not sure how to code a timer for it. i know how to make a timer and i know C code im just having difficulty bridging the two. The following Code is code i have for a countdown from 9 to 0, but im not sure how to get it to 60 and i dont want it to loop. but i can only seem to get it to work in a loop
// Define the LED digit patters, from 0 - 9
// Note that these patterns are for common cathode displays
// For common anode displays, change the 1's to 0's and 0's to 1's
// 1 = LED on, 0 = LED off, in this order:
//                                    Arduino pin: 2,3,4,5,6,7,8
byte seven_seg_digits[10][7] = {
    0,0,0,0,0,0,1   }
  ,  // = 0
    1,0,0,1,1,1,1   }
  ,  // = 1
    0,0,1,0,0,1,0   }
  ,  // = 2
    0,0,0,0,1,1,0   }
  ,  // = 3
    1,0,0,1,1,0,0   }
  ,  // = 4
    0,1,0,0,1,0,0   }
  ,  // = 5
    0,1,0,0,0,0,0   }
  ,  // = 6
    0,0,0,1,1,1,1   }
  ,  // = 7
    0,0,0,0,0,0,0   }
  ,  // = 8
    0,0,0,1,1,0,0,0,1,1   }   // = 9
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  writeDot(0);  // start with the "dot" off
void writeDot(byte dot) {
  digitalWrite(9, dot);
void sevenSegWrite(byte digit) {
  byte pin = 2;
  for (byte segCount = 0; segCount < 7; ++segCount) {
    digitalWrite(pin, seven_seg_digits[digit][segCount]);
    ++pin;
  for (byte count = 10; count > 0; --count) {
    sevenSegWrite(count - 1);
  delay(4000);
runaway_pancake
Place your code inside "code tags"
  • Copy your code
  • Click the # gadget (post/message toolbar) and then paste your code between the two html prompts [ code ] [ /code ]
This will countdown once:
boolean passthru = false;
byte tens;
byte ones;
void setup ()
void loop ()
  if (passthru == false)
    for (int counts=60; counts > -1; counts--)
      tens = counts/10;
      ones = counts % 10;
      Serial.print(tens,DEC);
      Serial.print(" ");
      Serial.print(ones,DEC);
      Serial.print("\r\n");
      delay (1000);
    passthru = true;
  // digitalRead switch for "do again"
  // >>> make passthru = false
Upload it, click the Serial Monitor button, and observe.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
