Topic: Help with Understanding code, getting to know millis() (Read 2471 times) previous topic - next topic
karl101
Hello,
I have written this program (below) that puts in a random pause before a function is called, and it appears to work. However I cannot say how it works. I thought millis() "Returns the number of milliseconds since the Arduino board began running the current program. This number will overflow (go back to zero), after approximately 50 days." http://arduino.cc/en/Reference/millis
So why do I see minus numbers on the output? such as the following:
pause for 3 seconds
pause: -32763 = clock: 29773 + (pause * 1000): 3000
:: doing something
pause for 4 seconds
pause: -31231 = clock: 30305 + (pause * 1000): 4000
:: doing something
I appear to be adding two positive numbers and getting a negative
const int PAUSE[] = {2,6}; // a pause of between 2 and 6 seconds
const int LED = 13;
boolean pWait = false;
boolean doThing = false;
unsigned long presentMillis = 0;
int pause = 0;
  randomSeed(analogRead(0));
  pinMode(LED, OUTPUT);
  digitalWrite(LED, LOW);
  unsigned long cMillis = millis();
  int clock = cMillis - presentMillis;
  if (pWait == false) {
    pause = random(PAUSE[0],PAUSE[1]);
    Serial.print("pause for ");
    Serial.print(pause);
    Serial.println(" seconds");
    int tmpP = pause;
    pause = clock + (pause * 1000);
    Serial.print("pause: ");
    Serial.print(" = clock: ");
    Serial.print(clock);
    Serial.print(" + (pause * 1000): ");
    Serial.println(tmpP * 1000);
    pWait = true;
    presentMillis = millis();
  if (clock > pause) {
    doThing = true;
  else {
    digitalWrite(LED, HIGH);
    doThing = false;
  if (doThing == true) {
    Serial.println(":: doing something\n");
    delay(500);   // pretend to be doing something
    pWait = false;
Thanks
Karl
wildbill
tmpP is an int (16 bits). You're seeing the results of overflow. Use unsigned long instead.
PaulS
Why is the previous time something happened called presentMillis?
nickgammon
When the measurement was taken, it was the present. :)
Henry_Best
But only for 1 millisecond.
nickgammon
The present is always ephemeral like that. It becomes the past, before you even know it. ;)
Henry_Best
My next Arduino project is going to be a time machine. I'm just waiting for the flux capacitors to arrive from China.  8)
boguz
uuuuuuu, i better go and clean my DeLorean!    8)
PaulS
Hope you got the big ones...  8)
PaulS
Did you get the model with the snow tires?  8)
Henry_Best
I could only afford the small ones, but they will get me far enough into the future to see what next weeks winning lottery numbers are.  8)
karl101
Thanks for the replies, I've made the amendment.
As it happens, I did have a couple of flux capacitors once, manufactured in China. I got them of eBay, But they leaked, very poor build quality.
Karl.
nickgammon
What, did you end up in the past? We've all been there.
Henry_Best
Deja vu ain't what it used to be!
