Topic: Hardware Serial Noob (Read 657 times) previous topic - next topic
stolzie
Hi Everyone,
Well I have jumped into the deep end as I have not played with Arduino before and I am after a little advice on implementing hardware serial on an Arduino Mega 2560 (mainly the receiving). What I would like to do is implement all the hardware serial ports on the device and connect it to various pieces of other equipment implementing different bauds to send commands and monitor what is actually going on.
The first serial port Serial 0 is connected to the programmer as well as a LCD running 9600 baud for debug purposes
Serial 1 - 4800 baud
Serial 2 - 2400 baud
Serial 3 - 4800 baud
Basically all I need to do is wait for a Test command on serial 0 (T), once received then send out various sequences to each of the other Serial ports and check for the correct response to come back and either pass or fail. What I have implemented so far, sends out the data and only receives some of the data back. I am pretty sure that I am hung up in loops and missing the responses that should be be received back. I have looked at the various serial examples and not sure if I have implemented the receive correctly.
Here is the code I have got so far, if someone can point in the right direction that would be fantastic. I am not sure what size the serial buffers on the arduino. I will be re-reading the manual to get a bit more of an idea what is going on.
//Intialise Variables Needed
int greenled = 2;
int redled =3;
int i = 0;
byte tempByte;
bool SendTestSeq = false;
bool TestFAIL = false;
const int buttonPin = 13;     // the number of the pushbutton pin
byte buf[6];
int buttonState = 0;         // variable for reading the pushbutton status
byte TXBuff[16];
byte RXBuff[16];
byte RXBuff1[16];
int RX1Index;
byte RXBuff2[16];   // for incoming serial data
int RX2Index;
byte RXBuff3[16];
int RX3Index;
void serialEvent()
  //Check Commands from LCD Screen +
      char command = Serial.read();
      Serial.write(command);
      switch(command)
        case 'T' : SendTestSequence(); //Send out Test Sequence
void serialEvent1()
RXBuff1[RX1Index] = Serial1.read();
RX1Index++;
void serialEvent2()
RXBuff2[RX2Index] = Serial2.read();
RX2Index++;
void serialEvent3()
RXBuff3[RX3Index] = Serial3.read();
RX3Index++;
  //Initialise Pins that are used
  pinMode(greenled, OUTPUT);
  pinMode(redled,OUTPUT);
  // InitialiSe the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // initialise Serial ports
  Serial1.begin(4800);
  Serial2.begin(2400); //2400
  Serial3.begin(4800);
  RX1Index = 0;
  RX2Index = 0;
  RX3Index = 0;
    //FLASH LED to indicate working
    digitalWrite(greenled, HIGH);   // turn the GreenLED on (HIGH is the voltage level)
    digitalWrite(redled,LOW);
    delay(50);
      digitalWrite(greenled, LOW);   // turn the GreenLED on (HIGH is the voltage level)
    digitalWrite(redled,HIGH);
    delay(50);
    //Check Serial Responses
     if(RX1Index == 3)
         // Serial.write("\n");
          //Recieve Modem Data
          TXBuff[0] = 0x64;
          TXBuff[1] = 0x02;
          TXBuff[2] = 0x66;
         //Serial.write("\n");
           if (array_cmp(TXBuff, RXBuff1, 2, 2) == true)
            // do this if they are equal
             Serial.write("Pass  \n");
             buf[0] = 0x50; //P
             buf[1] = 0x31; //1
             Serial.write(buf,2);
            // do this if they are different
            //Serial.write("Array Different\n");
             buf[0] = 0x46;
             buf[1] = 0x31;
         //Reset Index
         RX1Index = 0;
     if(RX2Index == 6)
         Serial.write("rx2\n");
          TXBuff[0] = 0xAA; //0x54 T
          TXBuff[1] = 0x7B; //0x45 E
          TXBuff[2] = 0x01; //0x53 S
          TXBuff[3] = 0x03; //0x54 T
          TXBuff[4] = 0x50; //0x45 E
          TXBuff[5] = 0x54; //0x52 R
           if (array_cmp(TXBuff, RXBuff2, 5, 5) == true)
            //Serial.write("Array Same\n");
             buf[0] = 0x50; //P
             buf[1] = 0x32; //1
             buf[0] = 0x46;
             buf[1] = 0x32;
         //Reset Index
         RX2Index = 0;
      if(RX3Index == 8)
          TXBuff[0] = 0x4E;
          TXBuff[1] = 0x32;
          TXBuff[2] = 0xAA;
          TXBuff[3] = 0x7B;
          TXBuff[4] = 0x01;
          TXBuff[5] = 0x03;
          TXBuff[6] = 0x50;
          TXBuff[7] = 0x54;
           if (array_cmp(TXBuff, RXBuff3, 7, 7) == true)
           // Serial.write("Array Same\n");
             buf[0] = 0x50; //P
             buf[1] = 0x33; //1
             buf[0] = 0x46;
             buf[1] = 0x33;
         //Reset Index
         RX3Index = 0;
boolean array_cmp(byte *a, byte *b, int len_a, int len_b){
      int n;
      // if their lengths are different, return false
      if (len_a != len_b) return false;
      // test each element to be the same. if not, return false
      for (n=0;n<len_a;n++)
      if (a[n]!=b[n])
      return false;
      //ok, if we have not returned yet, they are equal :)
      return true;
void SendTestSequence()
  //Send out Test sequence
  //Channel Change
  Serial.write("C");
  TXBuff[0] = 0x64;
  TXBuff[1] = 0x02;
  TXBuff[2] = 0x66;
  //Write Channel Change
  //Serial.write("WriteCh\n");
  Serial3.write(TXBuff, 3);
  //Wait
  //Send Modem Data
  TXBuff[0] = 0xAA;
  TXBuff[1] = 0x7B;
  TXBuff[2] = 0x01;
  TXBuff[3] = 0x03;
  TXBuff[4] = 0x80;
  TXBuff[5] = 0x84;
  //Write Send Modem Data
  //Serial.write("WriteModem\n");
  Serial.write("M");
  Serial3.write(TXBuff, 6);
  //Wait
  //Send ID Request
  TXBuff[0] = 0x3F; // Send ?
  TXBuff[1] = 0x13;
  TXBuff[2] = 0x10;
   //Write Send ID Request
//  Display.putstr("Sending ID Request\n");
// Serial.write("WriteID\n");
  Serial.write("I");
  //Wait
  TXBuff[0] = 0xAA;
  TXBuff[1] = 0x7B;
  TXBuff[2] = 0x01;
  TXBuff[3] = 0x03;
  TXBuff[4] = 0x50;
  TXBuff[5] = 0x54;
//   Serial.write("WriteRXMod\n"); //
  Serial.write("R");
  Serial2.write(TXBuff, 6);
  //Wait
Thanks for the support, stuck noob.
Henry_Best
Get rid of the delays, as during a delay() the arduino does nothing but wait for the delay to end. Look up the 'blink without delay' example in the Playground to learn how to overcome this problem.
stolzie
Thanks for information Henry, have implemented without delays and with a few other changes it all works.
Thanks,
Stolzie
Henry_Best
Thanks,
Stolzie
You're welcome. You could also look up 'switch case', to simplify your if - else statements.
