Topic: I2C - Problem with onRequest, onReceive (Read 665 times) previous topic - next topic
mzahor
Jul 15, 2013, 03:03 pm Last Edit: Jul 15, 2013, 03:07 pm by mzahor Reason: 1
I've problem with IDE 1.5.2 and Arduinu DUE.
My program size: 304,492 bytes
Free RAM: cca 70kB [ not 100% ] - used some code to get this number
Problems started after I've added Wire1 as I2C Slave and using :
- onRequest
- onReceive
The same problem with Wire and Wire1.
Since that program freezes at the same location - not in I2C callback [ I think ] but while drawing to TFT display.
I'm thinking about some Stack issue but can't [ don't know how ] investigate it more.
 Wire1.begin(NET_MODULE_WIRE_ADDRESS);
 Wire1.onRequest(onRequestHandler);
 Wire1.onReceive(onReceiveHandler);
void  onRequestHandler(void)
 byte val ;
 switch (cmd_received)
   //je queue prazdna ?
   case CMD_QUEUE_EMPTY:
     Wire1.write(RQX_HEADER);
     Wire1.write(queue[0].empty);
//receive command from network arduino UNO
void onReceiveHandler(int howMany )
 if(Wire1.available())
   cmd_received = Wire1.read();
