Topic: SPI conection on Due (Read 980 times) previous topic - next topic
robertocarlos
Which are the pins I should use for SPI comunication with arduino DUE? please specify all four wires for SCLK, MOSI, MISO and CS. I´m currently trying to conect an ADXL345 accelerometer to arduino DUE unsuccessfully using
10 for CS,
11 for SDA,
12 SDO and
13 SCL
pins. This work perfectly in my Arduino Duemilanove, but I need the 3 SPI conections (4 10 and 52)  capability of Due.
Thanks
Graynomad
#1
Jul 16, 2013, 01:02 am Last Edit: Jul 16, 2013, 01:11 am by Graynomad Reason: 1
Those signal names are not really SPI names, more a mix of I2C and SPI, are they from the ADXL345?
Anyway on the Due SPI is as follows
SCK - 76
MISO - 74
MOSI - 75
CS/SS - whatever pin you like. There are 2 dedicated slave select pins (D4/87 and D10/77) but I don't know if the SPI library uses them.
The pinout info is here
http://forum.arduino.cc/index.php?topic=132130.0
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
robertocarlos
Rob
thanks for answerring, I´ll try those pins.
In the picture is the accel that I´m using, ADXL345, so you can see the names of the conections.
One last thing, shouldn´t been 3 dedicated spi pins D4, D10 and D52?
thanks alot.
Roberto
Graynomad
Quote
and D52?
Yep. Missed that one.
Like I said though I'm not sure if the SPI lib uses them, I would assume not.
_____
Rob
gallegojm
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
