Topic: Pasar de String a int,float,long...[Solucionado] (Read 2696 times) previous topic - next topic
jorge_hura
Jul 17, 2013, 10:15 am Last Edit: Jul 18, 2013, 05:41 pm by jorge_hura Reason: 1
Buenas, tengo un proyecto en el que recibo a traves de un socket una cadena de caracteres y llegado un punto necesito convertir esa cadena en un numero, da igual de que tipo sea.
Ya he probado con atoi y atol, incluyendo la libreria <stdlib.h> pero me da el siguiente error:
cannot convert 'String' to 'const char*' for argument '1' to 'int atoi(const char*)'
gracias
fermg
Has probado con serial.parseint(), copio y pego lo que pone en la referencia de la pagina oficial de arduino;
Serial.parseInt() returns the first valid (long) integer number from the serial buffer. Characters that are not integers (or the minus sign) are skipped. Serial.parseInt() is terminated by the first character that is not a digit.
Serial.parseInt() inherits from the Stream utility class.
esta opción esta disponible a partir de IDE 1.0.
un saludo
jorge_hura
He encontrado una forma de hacerlo manualmente, pero gracias.
Dejo aqui la solucion por si le sirve a otro.
String tiempo[]={"0.","1.","2.","3.","4.","5.","6.","7.","8.","9.","10.","11.","12.","13.","14.","15.","16.","17.","18.","19.","20.","21.","22.","23.","24.","25.","26.","27.","28.","29.","30.","31.","32.","33.","34.","35.","36.","37.","38.","39.","40.","41.","42.","43.","44.","45.","46.","47.","48.","49.","50.","51.","52.","53.","54.","55.","56.","57.","58.","59."};
for(i=0;i<60;i++)
       if(tiempo == probando)// probando es la variable que recibo a traves de socket y que contiene el string a cambiar
         if(aux ==1)
         NuevaHora=i;
         Serial.print("La nueva hora introducida es");
         Serial.println(NuevaHora);
         aux=2;
         else if(aux=2)
           NuevoMinuto=i;
           Serial.println(NuevoMinuto);
           aux=0;
melvex
Aunque ya lo tienes solucionado, aquí te dejo cómo lo he arreglado yo:
long string2long(String string){
  char cadena[string.length()+1];
  string.toCharArray(cadena, string.length()+1);
  return atol(cadena);
Puedes modificarlo fácilmente para que pase a int, float o lo que quieras.
Saludos,
Manolo
Justiciero
tengo una duda  en donde puedo conseguir la libreria  stdlib.h
