Topic: how to detect coin mech pulses (Read 861 times) previous topic - next topic
steve_w
Hey,
I'd really appreciate some advice on a project that I'm right in the middle of.
I hope I've posted in the right section - I've searched the rest o the forum but I still don't really understand how to tackle my problem.
I'm trying to get a coin-mech (the type used in arcade machines) to work with the arduino. it
is a single coin type that allows the pulse to be set manually.
The wiring harness for the mech is as follows:
grey line: counter (+/-)
red line: DC +12V
White line: Coin Signal
Black Line GND
grey Line: counter (+/-)
The spec sheet for the mech states that the timer Switch, for synchronising the system has three options:
100ms
50ms
30ms
OK.. from what I understand i would need to use the White Line to ascertain when a correct coin has been inserted - counting the pulses, I believe..
Firstly, I haven't been able to work this out.
Secondly, I think I blew one of the pins by putting the line straight into my arduino - how do I avoid this?
Many thanks for any advice!
fungus
Did you connect all the ground lines together (mech+Arduino)?
What voltage do you measure on the white line with a multimeter?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
steve_w
Hi Fungus,
I haven't tied all the ground lines together should I do so?
The Voltage from the coin line is 6v
Thanks.
Grumpy_Mike
Yes all grounds need to be connected together.
liudr
If the coin mech gives 6V output, then you need a voltage divider to drop it to 5V. Try a white-1Kohm-5kohm-gnd circuit and use arduino to sense between the two resistors. What are grey counter +/-?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
