Topic: Arduino Due DAC Tutorial Problem (Read 3102 times) previous topic - next topic
rigelsix
Hello,
I'm trying to run a tutorial I found on the arduino site, here, using the due:
http://arduino.cc/en/Tutorial/DueSimpleWaveformGenerator
The compiler returns an error with the example code:  't_sample' was not declared in this scope
My frustration is that the variable declared directly above it seems to work just fine. What's the problem here? Is the compiler broken?
Here's the beginning of the program listed on the tutorial:
#include "Waveforms.h"
#define oneHzSample 1000000/maxSamplesNum  // sample for the 1Hz signal expressed in microseconds
const int button0 = 2, button1 = 3;
volatile int wave0 = 0, wave1 = 0;
int i = 0;
int sample;
 analogWriteResolution(12);  // set the analog output resolution to 12 bit (4096 levels)
 analogReadResolution(12);   // set the analog input resolution to 12 bit
 attachInterrupt(button0, wave0Select, RISING);  // Interrupt attached to the button connected to pin 2
 attachInterrupt(button1, wave1Select, RISING);  // Interrupt attached to the button connected to pin 3
 sample = 0;
 // Read the the potentiometer and map the value  between the maximum and the minimum sample available
 // 1 Hz is the minimum freq for the complete wave
 // 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
 sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
 sample = constrain(t_sample, 0, oneHzSample);
 analogWrite(DAC0, waveformsTable[wave0]);  // write the selected waveform on DAC0
 analogWrite(DAC1, waveformsTable[wave1]);  // write the selected waveform on DAC1
PaulS
Just remove the t_ from the name. It is the value from the previous line that is (supposed) to be constrained.
rigelsix
Can't believe I missed that. Thanks.
DuaneB
If you like the sounds that makes, here is a very similar but slightly more complex approach that make a far more entertaining set of sounds. Justvbe very careful what you connect your DAC output to, a few of us have burned them out.
http://rcarduino.blogspot.ae/2012/11/quick-and-dirty-synth-for-arduino-due.html
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
