Topic: Low switching transistor question (Read 801 times) previous topic - next topic
Gadget999
Jul 18, 2013, 01:00 pm Last Edit: Jul 18, 2013, 01:12 pm by Gadget999 Reason: 1
I want to use a transistor as a sort of Analogue to Digital convertor
i have a signal that is 0-5v - i want to switch an earth if i see a voltage that is greater than 0v  sometimes the voltages are very weak
is there a low switching transistor that is normally open that i can use
or should i be doing this a different way ?
i have some transistors on the shelf -  http://www.micropik.com/PDF/bc635.pdf
they look way too powerful to me
any advice appreciated
Gadget999
here is the spec of some on maplins web site
are any of them any good ?
VCEO    IC    PTOT    hFE    FT
                V    mA     mW       min/max MHz
2N3904    40    200    350    100/300    300
BC547C    45    100    500    420/800    100
BC550C    45    100    500    420/800    100
BC549C    45    200    200    420/800    100
BC635    45    1000    830    63/250    150
2N5551    160    600    500    80/250    100
http://www.maplin.co.uk/low-power-lf-npn-transistors-to92-case-32952
michael_x
These silicium npn bipolar transistors don't really differ in this aspect.
It's rather about which load they can switch.
They all need a VBEvoltage of about 0.8 V to switch on.
If this is beyond your "very weak voltage", you better look for an opamp or comparator.
Gadget999
thank you
it will probably be easier to read the 0-5v and do something with it that way
polymorph
You must choose a voltage. Do you really mean 0V? What is a real acceptable threshold? 1mV? 100mV?
There are comparators that can go down to the 0V rail or below. But if you want it to switch on "greater than 0V", you need to choose a threshhold.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - tinyurl.com/q7uqnvn
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Gadget999
Hi Polymorph
100mV would probably be ok as a threshold
Grumpy_Mike
Quote
Then you can't use a transistor, you need a voltage comparator or you need to read the voltage on the arduino's analogue input.
polymorph
Hi Polymorph
This can pretty easily be done with a comparator or Op Amp that can work down to ground. I am making an assumption that this is a single supply? No negative power supply line?
An LM339 is a quad comparator with open collector output. IE, it only pulls low.
You just need the non-inverting input connected to a resistive voltage divider so that it has 100mV on it. Then when the inverting input rises above 100mV, the output will be pulled to ground.
michael_x
If it's an arduino project, and you have a free analog input available, your
Quote
is definitely the easiest solution.
