Topic: Shift Register that can give me more than 8 pins ? (Read 2690 times) previous topic - next topic
firashelou
hello guys,
i need please a shift register that can give me more than 8 pins , maybe about 10 and more and is similar to the 595 ?
and thanks in advance
Aiming for the unreachable !
strykeroz
An easy way is to daisy-chain more 595's.  Check this example where two are used to drive 16 outputs (in this case simple LEDs).
Cheers !
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
firashelou
#2
Jul 18, 2013, 02:09 pm Last Edit: Jul 18, 2013, 02:12 pm by firashelou Reason: 1
yes i know it but it would be better if i get one IC in the circuit to have more space for other components
fungus
There's this: http://www.ti.com/lit/ds/symlink/sn74ls674.pdf
But they're double-wide so it won't save any space and don't ask me where you'd get one for less than about $40.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
firashelou
aw ok then no for sure i won't buy it !! the 595 cost is 0.5$ !! :D
pwillard
Yup, Mouser.com price: $31.10 and its roughly the equivalent of 2 cascaded 595's
BulletMagnet83
If you want to save space you could always use SMD ones for your final design... those packages aren't very challenging to solder and you can stuff a LOT of them in a small space.
firashelou
i don't know how to work with SMDs and i don't feel i like the SMD !!
MAS3
How about the PCA9555 ?
Has 16 bidirectional pins.
Don't know about availability, but the datasheet mentions through hole pins.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
cjdelphi
SMD 595's are the best way for 2 reasons.. 1. cost 2. space
firashelou
but it can be used as the normal one ?! i mean like it can't be soldered like you solder the normal IC
pwillard
why not.  I "normally" solder SMD's quite often with my normal soldering iron.  It takes a steady hand and some patience... but it works.
firashelou
well maybe someday i'll try it, cz i have an SMD chip but it's very very small, maybe a socket will make it easy
