Topic: Fading LED on pin 13 without delay. (Read 3889 times) previous topic - next topic
Haiji
I'm having trouble writing modifying this code that fades the LED on pin 13 on and off to do the exact same thing but without using any delays.
Here is the code which I currently have.
Code: [Select]
int ledPin = 13;
unsigned int i=0;
boolean fade=true;
int interval=1000;
void setup(){
  pinMode(ledPin, OUTPUT);
  if(i == interval)  {
    i=1;
    fade=!fade;
  if(fade == false)  {
    digitalWrite(13, LOW);
    delayMicroseconds(i);
    digitalWrite(13, HIGH);
    delayMicroseconds(interval-i);
  if(fade == true)  {
  i+=1;
So far, I converted some of the code but I don't know how to make the Arduino wait without interrupting other code I plan to have running simultaneously.
Can please give me some ideas?
Code: [Select]
int ledState = LOW;
long previous = 0;
long interval = 0;
boolean fade = true;
  pinMode(13, OUTPUT);
  unsigned long current = micros();
  if(current - previous > interval) {
    previous = current;
    fade = !fade;  //change fading
  //fade out
  if(fade == false)  {
  //fade in
  if(fade == true)  {
nickgammon
http://www.gammon.com.au/blink
Use millis ().
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
fungus
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Henry_Best
It would be much easier if you connected your LED on one of the PWM pins to control the fading.
CrossRoads
Easier with PWM, but certainly not required. I just wrote some code to output 13 notes from 13 button presses, with frequencies from 261 Hz to 523 Hz. Was certainly not hard using blink without delay type coding.
All you're doing is controlling the on/off time. Setup a time within a time - the outer time is how fast you are pulsing, the inner time is how long you leave the output high within the total time for brightness control.
nickgammon
