Topic: I don't understand relays (Read 1 time) previous topic - next topic
PM5K
I bought a Seed Studio relay shield at Radio Shack for 20.00.
The relay says 3A 120VAC    3A 24VDC. The board is powered by 9-12 volts DC.
First of all can you control lower voltage than specified? Say 12VAC or 12VDC?
Also, and more importantly, where do I get the power from? The board is only getting 12VDC so if I want to power something that takes 12VAC how would I do that?
TIA
runaway_pancake
You're not supposed to do line voltage with that board at all.
They didn't design it for that sort of high voltage (it's totally not UL.)
It has no agency approvals for anything of the kind.
[Especially since the traces for the terminals and relay traces are so close to the Arduino USB connector shell.]
Yes, you can use voltages lower than the rated voltages on the relay labels.
You bring the voltage that you want to switch into one of the relay terminals (COM) and look for it at that relay's NC (normally closed) or NO (normally open) contact.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
PM5K
I always seem to get a bit of a clue after posting on here.
Is it correct that the AC or DC voltage comes from elsewhere and that the relay only controls the ground?
I'm just trying to figure out if I can interface the shield with 12VAC landscape lighting.
(Just read the reply and didn't totally get it.) Especially the very first line if your reply.
runaway_pancake
With regard to the "first line" of my previous reply: Do NOT use this for 120 vac !
http://forum.arduino.cc/index.php?topic=165923.msg1239161#msg1239161
MAS3
You can use it for 12 V AC.
But as stated, be real sure it doesn't touch any parts ofthe Arduino.
You could consider to extend the headers of the Arduino to be sure.
I've seen some shields that get too close to the USB connector shell to my taste, but haven't acutally seen these shields.
Runaway Pancake has as you can see in his link.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
PM5K
Interesting, because on their website they say you can.
So let's say I'm working with AC voltage, how would I wire that up, because the lines are reversible.
larryd
Quote
How much current is flowing in your 12VAC lighting circuit?
No technical PMs.
The last thing you did is where you should start looking.
PM5K
I think the power supply is more than it's capable of.
If it does 3A @ 24VAC, how would I know what amperage it could handle at 12VAC?
If I had to guess I'd say in the neighborhood of 6A, but I have a feeling that's wrong.
PM5K
The output is 12VAC 3.75 amps.
MAS3
#9
Jul 19, 2013, 02:30 am Last Edit: Jul 19, 2013, 02:32 am by MAS3 Reason: 1
Cut 1 line and connect it through the relay.
PSU side to COM and lamp side to NO.
3A is your maximal current.
The difference between the AC and DC voltages is due to AC is alternating and will go through 0 volts 100 - 120 times per second.
A switch off spark will be stopped at that moment, and this will not occur when using DC current.
So a DC voltage will generate sparks for a longer time, damaging the contacts more.
PM5K
I'm not sure what you just said.
However, if I can't do more than 3AMPS @ 12VAC, can I knock it down somehow? I'd imagine the lights will still work, they just wouldn't be as bright.
larryd
Some reading on relays:
http://www.electronics-tutorials.ws/io/io_5.html
Quote
If this is the power supply rating, you probably are running less than 3.75 amps in the actual lighting circuit.
Best measure the actual current with a meter.
No technical PMs.
PM5K
So I could just knock out a couple of lights from the set which would knock down the draw if necessary.
I do have a multimeter to check with.
Also, I was planning on separating the lights into four sets of two, so the load to each relay would be less right, less than an amp draw on each.
But how would I wire it?
I know how to do DC from the link Runaway Pancake posted, but AC?
runaway_pancake
It's the same concept, the relay contacts (being a switch, an SPDT) completes / interrupts the circuit.
DWG attached.
cjdelphi
Basically, a relay is simply a "switch"
The switch gets opened or closed depending on if there's a built up magnetic field (an electromagnetic) you power the electromagnetic
with your arduino (or transistor in this case), once the magnetic field occurs, it will repel off a perm magnetic which pushes the metal
contacts together...
When the contacts form, electricity will flow...
