Topic: battery density (Read 10237 times) previous topic - next topic
arduinopi
I realize today that battery capacity is a limiting factor in designing something. Theoretically would it be possible (one day in the future) for a battery the size of a AA to have a capacity of say 12 volts at 20 amps an hour? I realize we are far from this, but about how long do you think it will take?
All of my projects --> http://www.frankmagazu.com/
cjdelphi
our only hope for anything remotely like that hangs in the balance with graphene.
CrossRoads
Maybe a fuel cell will be able to do that.
John_Smith
You are talking about half a small car battery capacity there,  there are urban legends that smaller better cheaper batteries have been invented over the years, but the big battery manufacturers buy the patent and throw it in a cupboard.
I think though that the boom in hybrid cars will lead the way in battery design ..
45 years of editing projects with a knife and soldering iron, then I found Arduino !
RamJam
Moors law doesn't seem to apply when it comes to batteries. Maybe the energy density doubles every 30 years. So 120 years.
GoForSmoke
Look at how much less power electronics use now compared to 40-50 years ago. That trend should on the way down meet batteries on the way up.
Use of earbuds instead of speakers, leds and LCD's and other efficiencies may have room to go yet.
And there's lots of room for self-power. The hand-heat powered flashlight is one beginning. Piezos in shoe soles is another. Put solar cells in your project, been around for decades. With super-capacitor improvements to store generated power, batteries will just be another choice.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
John_Smith
My dilemma is that I need 150 watts of power to drive a cricket scoreboard ( for example ) if it is facing the sun.
So if somebody wants a battery powered scoreboard they have to basically park a car behind it.
The new generation LEDs show up fine in direct sunlight, but I use 4 LED strings per segment ( of the 7 segment displays )
If I could drive just 2 rows on overcast days they would show up fine, but to power the other 2 rows from a solar panel would cost half the price again of the scoreboard.
I use LCD displays on some of the remote controls, but they are useless in sunlight ( at least the cheap backlit ones I have used. )
I havn't had chance to read up on LCD displays, but presumably there is a limit to the amount of light the display can block when the crystals are aligned ?
It would be nice to be able to have a simple backlight for low ambient light, and to have a mirror / lens arrangement for the sun to illuminate from behind on sunny days, but I don't know if LCD screens could handle this.
GoForSmoke
Would it be any good to use flip-dots? Or some kind of stepper-driven card rolodex?
John_Smith
I have made quite a few boards to replace flip dot types, they just cant take the heat in the sun.
( I made a hotel roomrate board for a swanky hotel , and they insisted on a stainless steel case for it.
If I have to do a service call on it in summer, I take gloves to take the lid off as it is so hot you could fry an egg on it.
Strangely enough, even though LEDs are not supposed to like heat, I have only had about 6 fail in 2 years in this board, out of the 1500 in that sign.   The fan doesn't last a year though and has to be replaced )
I have thought of some sort of rotating tubes driven by a cheap motor, for the 7 seg displays  but haven't had the time to experiment yet.
Another problem is if they require team names, and I end up with 35 LED strings per character, with usually 8 letters per team so its another 560 LED strings to be powered - if I multiplex it, it brings down the current but the LEDs are hard to see in sunlight.
I think I must keep an eye on the prices of solar panels as they come down, but how do you find a reliable one?
GoForSmoke
That has all the sounds of a need to be met. How much solution can they afford?
RamJam
Therefore all progress depends on dispairing clients  :D
John_Smith
There not a lot of money around at the moment,  so everything has to be cut to the bone, to keep the quotes down.
GoForSmoke
Have you tried shading the board?
John_Smith
Up until about a year ago I used to fit the LED in routed grooves in a plastic front panel, to shade each row of LEDs.
It was fiddly and expensive to do, and if the board was pointed towards the North East the sun still got to the LEDs in late afternoon ( we are in the Southern hemisphere )
  ( I love it when they ask for a southern facing board so it is always shaded )
Now the LEDs are so bright that shading is not needed, but it still needs a double row :-
These are leant back looking straight into the sun so not shaded by the grooves, and are perfectly clear.
The latest ones are even better, and for evening sport the auto dimming I have had to fit turns them right down to less than 10% duty cycle.
One of the problems is that schools and clubs want the scoreboard across the field from the clubhouse, often where there is no power.
Sinking cable around the field is very expensive, and could kill the sale, so if I can get affordable solar panels ( and deep cycle battery ) it might swing some sales.
Nishant_Sood
I'm waiting for the nuclear batteries.
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
