Topic: Using a Piezeo Element to read analog values (Read 989 times) previous topic - next topic
iisfaq
Jul 20, 2013, 02:35 am Last Edit: Jul 20, 2013, 02:50 am by iisfaq Reason: 1
Hi
I am using an UNO and a piezeo element connected directly between ground and A0
The additional wires (red + orange) are only being used to hold the very small Piezeo wires in place - nothing else.
My code is
int sensorPin = A0;    // select the input pin for the potentiometer
int sensorValue = 0;  // variable to store the value coming from the sensor
 // declare the ledPin as an OUTPUT:
 pinMode(ledPin, OUTPUT);
 // read the value from the sensor:
 sensorValue = 1023-analogRead(sensorPin);
 // turn the ledPin on
 Serial.println(sensorValue);
delay(100);
This runs full speed and generally returns 0 if nothing is going on. But if I touch/tap the piezeo element it changes values say jumps to 600 and then slowly reduces back to 0.
This reduction to 0 can take 30 seconds.
I would have expected a much quicker drop to 0
If I was using this to record audio (such as a rain drop or hail) I would need much quicker reduction to 0 since one strong hail stone would be only a few ms not 30 seconds.
Any ideas on what I need to ensure a quicker drop and why it is doing this?
Could there really be that much energy being released over 30 seconds?
Chris
larryd
Have you seen this?
http://www.arduino.cc/en/Tutorial/KnockSensor
No technical PMs.
The last thing you did is where you should start looking.
iisfaq
OK I have found that if I put a 1M resister between the Red + Black legs of the Piezieo element then I get good data.
Thanks for the info on the knock sensor - it helped but I found it on a youtube video and not on here.
cheers
I have also changed the loop to
 sensorValue = analogRead(sensorPin);
if (sensorValue >= 5)
 delay(100);
So I now have
A0 connected to 1 Leg of 1M resister and then connected to RED leg of Piezo
GND connected to other leg of 1M and then connected to BLACK leg of Piezo
chris
