Topic: ARDUINO TO OPERATE A RELAY REMOTELY (Read 2761 times) previous topic - next topic
love7007
Jul 20, 2013, 09:01 pm Last Edit: Jul 20, 2013, 09:48 pm by love7007 Reason: 1
i coped the code from http://forum.arduino.cc/index.php?topic=177551.msg1322776#msg1322776nothing similarity but but the code below is  using 2 commands  of light senser after a interval i want it to accept 5 commands with interval and light pin 13 to a given period of time ,actually i will  place a old phone on the light senser and give 5 miss call  after a interval of time making the relay to switch on
Code: [Select]
[code]///////Define Pins
int sensepin = 0;
int ledpin =13;
int Counter1 = 0; //Relay closed seconds counter
int Counter2 = 0; //Relay closed minutes counter
int Counter3 = 0; //Relay open seconds counter
int Counter4 = 0; //Relay open minutes counte
 analogReference(DEFAULT);
 pinMode (ledpin, OUTPUT);  //The LED pin needs to be set as an output
void blinkonce ( ) {
 digitalWrite(ledpin,HIGH);
 delay(900000);//delay(1800000)= HALF HOUR ,,,delay(900000)IS 15 MIN
 digitalWrite(ledpin,LOW);
 do{
   delay(80000); // delay for of time
  int val = analogRead(sensepin);
   Serial.println (val);
 if (val >10 )  //if the value is (val > 70)?
  // read the state of the relay value:
  sensepin = digitalRead(sensepin);
 // check if the relay is closed.
  if (sensepin == LOW) {
    digitalWrite(sensepin,LOW);
      Counter1++; //Increment seconds closed counter
         if (Counter1 > 10){
     Counter2++; //Increment minutes closed counter
     Counter1 = 0;}//Reset seconds closed counter
     delay(60000); // delay for of time
    }while (sensepin == LOW);//Continue until relay opens
       if (sensepin == HIGH){ //Print the total minutes closed
       Serial.print("Minutes On: ");
       Serial.println(Counter2);
       Counter2 = 0;
 do{
 // check if the relay is open.
   // turn LED off:
    digitalWrite(sensepin, LOW);
     delay(60000); //delay for of time
      Counter3++; //Increment seconds open counter
    delay(1000); //Wait one second
    if (Counter3 > 10){
     Counter4++; //Increment minutes off counter.
     Counter3 = 0;}//Reset seconds off counter
    }while (sensepin == LOW);//Continue until relay closes
       if (sensepin == HIGH){ //Print the total minutes open
       Serial.print("Minutes Off: ");
       Serial.println(Counter4);
       Counter4 = 0;//Reset minutes off counter
        blinkonce();
[/code]
AWOL
Did you have a question?
Why are you SHOUTING?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
