Topic: Nil RTOS update - Fast and Tiny! (Read 41402 times) previous topic - next topic
pito
#15
Aug 17, 2013, 05:43 pm Last Edit: Aug 17, 2013, 08:38 pm by pito Reason: 1
Now the NilTimeNow() and millis() are identical (I've changed the systime to uint32_t):
Quote
382938 382933
563120 563115
808810 808806
1160186 1160182
1770719 1770715
10808014 10808011
Q: what will happen when the compare value drifts closer to 255/0 (OVF isr for millis) because of "OCR0A += 250;" ?
fat16lib
Quote
The timer counter, TCNT0, just increments and the overflow ISR doesn't change anything.  So the compare ISR is not affected by the overflow ISR.
Adding 250 really just subtracts 6 counts or 24 microseconds until the next compare match.  As long as interrupt are not disabled for around a millisecond this will be reliable.
pito
So when compare value will be 0, the ovf and compare isr fire simultaneously, I think. Will be both isrs processed properly then?
fat16lib
Quote
It will work correctly but there will be a little jitter in the time.  Interrupt priority on AVR is by vector location.
Quote
The interrupts have priority in accordance with their Interrupt Vector position. The lower the Interrupt Vector address, the higher the priority.
The TIMER0 COMPA interrupt is higher priority than TIMER0 OVF so the Nil systick should be processed first if both occur on the same CPU cycle.
pito
#19
Aug 20, 2013, 04:38 pm Last Edit: Aug 20, 2013, 05:05 pm by pito Reason: 1
I have several tasks, two of them handle I2C. First reads ads1110 ADC (per. every 100ms) and the second one reads an external RTC (for example each second). Running both tasks accessing single I2C bus does not work well - it comes to data corruption.
What is the proper handling of such situation under NilRtos?
fat16lib
You could share the I2C bus by using a semaphore. Each thread that uses the I2C bus has this form.
Code: [Select]
// Declare and initialize a semaphore for limiting access to a region.
SEMAPHORE_DECL(i2cSem, 1);
// Time between acceses.
const systime_t PERIOD_ONE_TICKS = 123;  // set value for your case!
// Declare the thread function.
NIL_THREAD(thdFcn, arg) {
  // Time for next read.
  systime_t wakeTime = nilTimeNow();
  while (true) {
    wakeTime += PERIOD_ONE_TICKS;
    // Sleep until time for next bus access.
    nilThdSleepUntil(wakeTime);
    // Wait for access to I2C bus.
    nilSemWait(&i2cSem);
    // Access I2C bus here.
    // Release I2C bus.
    nilSemSignal(&i2cSem);
Another option is to access one of the devices with software I2C.
See: DigitalIO20130221.zip  - Fast digital I/O, software I2C, and software SPI http://code.google.com/p/rtoslibs/downloads/list.
pito
#21
Aug 20, 2013, 09:02 pm Last Edit: Aug 20, 2013, 10:26 pm by pito Reason: 1
ok, so something like handshaking:
Code: [Select]
   nilSemWait(&i2cSem);                     <<  waits on signal I2C is free (resource semaphore 1 -> 0 )
   // Release I2C bus.
   nilSemSignal(&i2cSem);                   >>  signals I2C is free (resource semaphore 0 -> 1 )
I'll try..
thx..it seems it works.. now I know why we need counting semaphores :)
fat16lib
It might be nice if Nil had a Mutex which is intended for mutual exclusion.  Here is an excellent little article http://www.chibios.org/dokuwiki/doku.php?id=chibios:articles:semaphores_mutexes.
pito
#23
Aug 21, 2013, 11:46 pm Last Edit: Aug 21, 2013, 11:55 pm by pito Reason: 1
Could be the setsyncProvider() with setSyncInterval() used in setup() with Nirtos? Or better, a task shall be used for syncing (instead of the setSyncInterval())?
Code: [Select]
   setSyncProvider(RTC.get);   // the function to get the time from the actual RTC
    setSyncInterval(300);         // set the number of seconds between re-sync of time
    nilSysBegin();
fat16lib
What are setSyncProvider() and setSyncInterval()?  They are not in the posted version of NilRTOS.
pito
#25
Aug 22, 2013, 11:32 am Last Edit: Aug 22, 2013, 12:56 pm by pito Reason: 1
It comes from Time.h
PS:  setSyncProvider() calls RTC in regular intervals in order to sync "local time" (based on millis(). So it seems it must be guarded by a mutex.
fat16lib
You just need to define a protected function to return the time.  All access to I2C must be protected by the same semaphore.
Code: [Select]
time_t safeGetTime() {
  time_t t;
  t = RTC.get();
  return t;
  setSyncProvider(safeGetTime);   // the function to get the time from the actual RTC
pito
#27
Aug 22, 2013, 05:14 pm Last Edit: Aug 22, 2013, 07:16 pm by pito Reason: 1
I did it with a periodic task. Yours is more resource friendly, of course :)
Code: [Select]
while (TRUE) {
wakeTime += SYSTIME_SYNC_PERIOD_TICKS;
// Sleep until time for next data point
// Read RTC..
nilSemWait(&i2cfree);
new_time = rtc.get_tm();
nilSemSignal(&i2cfree);
// .. and sync system Time and Date
setTime(new_time);
now();  // this makes the sync
Q: can I work with semaphores before I start the NilRtos? Like:
Code: [Select]
// SYNC the RTC and systime at boot
setSyncProvider(safeGetTime);   // the function to get the time from RTC
if(timeStatus()!= timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
sys_t_start = now(); // keep the boot start time
nilSysBegin();
While running above I get a proper time into "sys_t_start" var - it means the setSyncProvider() has called the safeGetTime() already.. So it had worked with semaphores, before the NilRtos actually started..
fat16lib
You will get away with calling safeGetTime before starting Nil since there will be no wait on the semaphore.  nilSemWait will decrement the count to zero and return.
It won't work if you need to wait.
pito
#29
Aug 24, 2013, 06:23 pm Last Edit: Aug 24, 2013, 06:36 pm by pito Reason: 1
I've installed SdFat's demos (Bench and SdInfo) into my Nil experimental setup. The issue is they use SdFat and Sd2Card respectively. So to put them together work with
Code: [Select]
SdFat sd;
Sd2Card card;
only, I was not able to merge the stuff such it uses only one class for the card. And it works :smiley-eek: (very surprised though) under Nil even under "heavy" load (several periodic tasks run in bg)  ;).
Code: [Select]
PITO> sdinfo
SDINFO
SdFat version: 20130710
init time: 15 ms
Card type: SDHC
Manufacturer ID: 0X3
OEM ID: SD
Product: SU04G
Version: 8.0
Serial number: 35763829101
Manufacturing date: 11/2012
cardSize: 3965.19 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
SD Partition Table
part,boot,type,start,length
1,0X0,0XB,8192,7733248
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT32
blocksPerCluster: 64
clusterCount: 120704
freeClusters: 112067
freeSpace: 3672.21 MB (MB = 1,000,000 bytes)
fatStartBlock: 14496
fatCount: 2
blocksPerFat: 944
rootDirStart: 2
dataStartBlock: 16384
PITO> sdbench
SDBENCH
Free RAM: -1203
Type is FAT32
File size 5MB
Buffer size 1024 bytes
Starting write test.  Please wait up to a minute
Write 140.21 KB/sec
Maximum latency: 442936 usec, Minimum Latency: 3252 usec, Avg Latency: 7294 usec
Starting read test.  Please wait up to a minute
Read 400.25 KB/sec
Maximum latency: 5784 usec, Minimum Latency: 2196 usec, Avg Latency: 2551 usec
Done
PITO> stack
STACK
Stack Sizes: 197 85 85 101 101 85 117 85 117 197 85 197 165 197 197 309 309 10107
Unused Stack: 165 55 55 47 49 55 87 55 87 58 55 167 41 71 167 192 50 9995
PITO>
BTW the FreeRam() does not work under Nil well.
