Topic: [Published on GitHub] LinkedList Class (Fully implemented) (Read 14008 times) previous topic - next topic
ivanseidel
Jul 21, 2013, 02:58 am Last Edit: Jul 21, 2013, 03:10 am by ivanseidel Reason: 1
Hi folks,
I have published my LinkedList Class on GitHub. It's REALLY usefull for all kinds of libraries and projects.
Features that are implemented:
  • LinkedList<T>::LinkedList() - Constructor.
  • LinkedList<T>::~LinkedList() - Destructor. Clear Nodes to minimize memory.
  • int LinkedList<T>::size() - Returns the current size of the list.
  • bool LinkedList<T>::add(T) - Add element T at the END of the list.
  • bool LinkedList<T>::add(int index, T) - Add element T at index of the list.
  • bool LinkedList<T>::unshift(T) - Add element T at the BEGINNING of the list.
  • bool LinkedList<T>::set(int index, T) - Set the element at index to T.
  • T LinkedList<T>::remove(int index) - Remove element at index. Return the removed element.
  • T LinkedList<T>::pop() - Remove the LAST element. Return the removed element.
  • T LinkedList<T>::shift() - Remove the FIRST element. Return the removed element.
  • T LinkedList<T>::get(int index) - Return the element at index.
  • void LinkedList<T>::clear() - Removes all elements.
For more information, and Latest releases go to https://github.com/ivanseidel/LinkedList
Fell free to commit new changes and use it.
Ivan
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
ivanseidel
ivanseidel
-------- NEW VERSION --------
1.1 (2013-08-03): Cache implemented. Getting subsequent objects is now O(N). Before, O(N^2).
We made a simple test, reading 1000 sequently elements 100 times and took the time needed to do it:
With previous version (Without caching system), took about 45000 miliseconds
With the new version (with a simple caching system), took 750 miliseconds
Update now and enjoy =)
robtillaart
Have you tried to implement skiplists ?
skiplists are fast dynamic datastructures, use 2n nodes for n values, and have an on average accestime of (Log(n))
- http://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-046j-introduction-to-algorithms-sma-5503-fall-2005/video-lectures/lecture-12-skip-lists/ -
fun structure to implement!
Rob Tillaart
ivanseidel
That's cool! I had one idea like that, but didn't know it had a name...
If you want to, you can doit. If it's easy to use, then I can merge with the existing one =)
Thanks for the idea.
Ivan
Molex1701
Hello,
  It looks like this is suppose to work with our own Class but when I try it, LinkedList gives a lot of errors.  Looks to be very useful, I hope I can use it.  Thanks.
Code: [Select]
#include <LinkedList.h>
LinkedList<int> myLinkedList = LinkedList<int>();
class test
public:
  test();
  int x;
test::test(){}
LinkedList<test> *myLinkedList2 = LinkedList<test>();
Code: [Select]
sketch_feb03a.ino: In constructor 'ListNode<test>::ListNode()':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:18:   instantiated from 'bool LinkedList<T>::add(int, T) [with T = test]'
sketch_feb03a.ino:17:   instantiated from here
sketch_feb03a:9: error: 'test::test()' is private
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:18: error: within this context
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h: In member function 'bool LinkedList<T>::add(int, T) [with T = test]':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:175: note: synthesized method 'ListNode<test>::ListNode()' first required here
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h: In member function 'T LinkedList<T>::remove(int) [with T = test]':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:286: error: conversion from 'bool' to non-scalar type 'test' requested
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:301: error: conversion from 'bool' to non-scalar type 'test' requested
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h: In member function 'T LinkedList<T>::pop() [with T = test]':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:239: error: conversion from 'bool' to non-scalar type 'test' requested
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h: In member function 'T LinkedList<T>::shift() [with T = test]':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:265: error: conversion from 'bool' to non-scalar type 'test' requested
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h: In member function 'T LinkedList<T>::get(int, bool) [with T = test]':
C:\Users\Richard\Documents\Arduino\libraries\LinkedList/LinkedList.h:308: error: no match for ternary 'operator?:' in '(tmp != 0u) ? tmp->ListNode<test>::data : false'
I've tried with  LinkedList<int> *myLinkedList = LinkedList<int>(); then I just get a message about converting.
ivanseidel
Hi!
Take a look at pointers and objects by instance to understand it better. But in your case you are trying to instantiate a poiinter linked list with an instance.object...
Also, when working with the list within different scope (loop, void, classes...), its a good practice to instantiate as a poiter. (If there will be lots of classes, its a good idea to delete it after you dont need it anymore).
What i use to do is:
Code: [Select]
LinkedList<mytype> *myList;
void setup{
  myList = new LinkedList<mytype>();
// In your code
myList->add(....);
Molex1701
  Thanks for fast response.  Unfortunately that doesn't work either.  Same errors.   Computers have really been troublesome for me lately. lol.
pYro_65
#9
Feb 05, 2014, 05:39 am Last Edit: Feb 05, 2014, 06:01 am by pYro_65 Reason: 1
Hi, @Molex1701 there may be a requirement for your class to implement certain operators as your class is not a POD ( you have a default constructor ). But there seems to be more problems, I believe there is a slight bug.
@ivanseidel, your remove function assumes that bool can be converted to any type of T.
Code: [Select]
if(index < 0 || index >= _size)
 return false;
Maybe return a default initialized value:
Code: [Select]
 return T();
This now only assumes that T has a default constructor or is a POD.
The same scenario appears in other functions.
Forum Mod anyone?
https://arduino.land/Moduino/
ivanseidel
Sorry for my (fast) but wrong response!
Now I had time to try it out, and seems that you are trying to 'include' the instance of the object, not the pointer to it. Here is how I would do, because then you are still able of passing the object without having to copy it or anything else...
Note that, the type of the LinkedList is not pointer, but the class inside it is. So, if you are adding elements to it, if they are instance objects (not pointers), don't forget the '&' before it...
Perhaps I could work out some examples for the library...
Code: [Select]
class test
public:
  test();
  int x;
test::test(){}
LinkedList<test*> myLinkedList2 = LinkedList<test*>();
ivanseidel
Code: [Select]
 return false;
Code: [Select]
 return T();
I think the problem is in fact, storing things larger than a simple pointer to a memory, number, boolean...
returning T(); would only work for object types that are NOT pointers, right?
pYro_65
No, default initialization will work on any type that is a POD, primitive, or object that has a default constructor:
Code: [Select]
typedef int* iptr;
iptr i = iptr(); //Works fine.
Forum Mod anyone?
Molex1701
Hi!
Code: [Select]
void setup{
// In your code
myList->add(....);
Hello,
Thanks for the additional help.  That got me going.  Here is some updated code showing it so that others might get help too:
Code: [Select]
class myNumber
public:
  myNumber();
  myNumber(int x);
  int _x;
myNumber::myNumber(){}
myNumber::myNumber(int x)
  _x=x;
//storing a address pointing to Class.
LinkedList<myNumber*> myNumbers = LinkedList<myNumber*>();
  Serial.print("Size ");
  Serial.println(myNumbers.size());
  //make object
  myNumber object(33);
                //Give list the address to store
  myNumbers.add(&object);
  Serial.println(myNumbers.size()); //See if list grew
  // get returned the address to the object
  // Access members with the -> pointer
  Serial.println(myNumbers.get(0)->_x); // Print out value
khristopheryan
Hi good day. I tried to use your library to implement my linked list, here's the code that I made:
Code: [Select]
uint8_t buf[16] = {255, 200, 0x03, 0x84, 0x05, 0x06, 0x07, 0x08, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00};
class IP
  public:
    char *name;
char *string, *stringA, *temp;
LinkedList<IP *> myList = LinkedList<IP *>();
  string = (char *)malloc(sizeof(char *)*1024);
  stringA = (char *)malloc(sizeof(char *)*1024);
  temp = (char *)malloc(sizeof(char *)*1024);
  int cnt = 0;
  char a[256];
  for(int x = 0; x < sizeof(buf); x++)
    cnt++;
    sprintf(a, "%02X", (uint8_t)buf[x]);
    strcat(stringA, a);
    if(cnt%4 == 0)
      if(strcmp(stringA, "00000000") != 0)
        strcat(string, stringA);
      strcpy(stringA, "");
    buf[x] += 1;
  int len = strlen(string);
  while(len > 0)
    snprintf(temp, 9, "%s", string+len-8);
    strcat(stringA, temp);
    if(len > 8)
      strcat(stringA, "-");
    len -= 8;
  IP *ip = new IP();
  ip->name = stringA;
  myList.add(ip);
  IP *route;
  Serial.print("Size: ");
  Serial.println(myList.size());
  for(int f = 0; f < myList.size(); f++)
    route = myList.get(f);
    Serial.println(route->name);
  strcpy(string, "");
  strcpy(temp, "");
I'm expecting my output to be:
Code: [Select]
00002000-00030000-05060708-FFC80384
01012101-01040101-06070809-00C90485
02022202-02050202-0708090A-01CA0586
03032303-03060303-08090A0B-02CB0687
04042404-04070404-090A0B0C-03CC0788
05052505-05080505-0A0B0C0D-04CD0889
06062606-06090606-0B0C0D0E-05CE098A
however, i got
Code: [Select]
I'm wondering what could be the problem.
Thanks.
