Topic: Latest Ethernet shield - used pins, how to bypass restrictions (Read 3027 times) previous topic - next topic
K5CZ
Jul 21, 2013, 09:03 pm Last Edit: Jul 21, 2013, 09:05 pm by K5CZ Reason: 1
Hi, I'm new in this and I do not understand of pins occupation. I looked at the Eagle PCB file I saw used these pins:
PD2 (digital 2)
PD4 (digital 4)
PB2 (digital 10)
PB3 (ICSP header)
PB4 (ICSP header)
PB5 (ICSP header)
PC6 (ICSP header)
I looked at schematics too and I saw used these pins:
JHIGH
hole number 3 - SS (PB2 - digital 10)
hole number 7 - GND (GND)
hole number 8 - AHREF (AHREF)
JLOW
hole number 1 - PD0 (digital 0) - but not connected
hole number 2 - PD1 (digital 1) - but not connected
hole number 3 - PD2 (digital 2) - but not connected
hole number 4 - PD3 (digital 3) - but not connected
hole number 5 - SD_CS (digital 4)
Official page says:
The onboard microSD card reader is accessible through the SD Library. When working with this library, SS is on Pin 4.
I understand. This means, that digital pin 4 is not available if SD card reader is used present. Someone says: To disable the SD card by switching pin 4 high
 pinMode(4, OUTPUT);
 digitalWrite(4, HIGH);
OK. And continue in reading:  Arduino communicates with both the W5100 and SD card using the SPI bus (through the ICSP header). This is on digital pins 11, 12, and 13 on the Duemilanove and pins 50, 51, and 52 on the Mega. On both boards, pin 10 is used to select the W5100 and pin 4 for the SD card. These pins cannot be used for general i/o.
And now, I'm confused. Which pins are definitively occupied and cannot be used as input or output? Only 4, 10, 11, 12 and 13?
johnwasser
The W5100 "*INT" pin (number 56) goes through a solder jumper to "PD2" (Arduino Pin 2).  If you add that jumper you have to use Pin 2 for the interrupt signal.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
PaulS
Quote
On which Arduino?
Quote
On a 328-based Arduino, yes.
K5CZ
http://shieldlist.org/arduino/ethernet-v5
Just by chance I found the information that A0 and A1 are used too. I see that those shields is full of surprises...  :smiley-eek:
