Topic: problem using Software Serial (Read 3705 times) previous topic - next topic
ThunderWiring
hello ,
im having a problem using the software serial library.
basically, i want to send an analog value from one arduino board to another(both are uno)
circuit: http://imageshack.us/photo/my-images/10/21sz.jpg/
code for tx board:
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12,13); // RX, TX
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  pinMode(0,INPUT); // pot analog value.
  pinMode(12,INPUT);//rx
  pinMode(13,OUTPUT); //tx
  Serial.write(analogRead(0));
  if(Serial.available()>0)
    mySerial.write(Serial.read());
code for rx board:
Code: [Select]
mySerial.listen();
  if (mySerial.available()>0)
    if(mySerial.read()<400)
      //do something
    else if(mySerial.read()>900)
      //do something else
any idea what went wrong?
thanks.
Regards,
ThunderWiring
robtillaart
The receiving arduino receives the character representation, not the numeric value
you must make a parser that builds up the number one digit at a time.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
ThunderWiring
i dont think thats the problem, because even if it is, the data which is being recieved is corrupted; it shows -1 all the time!!
Regards,
ThunderWiring
robtillaart
-1 means that there are no characters received,
Have you connected the TX of the sender to the receiver RX ?
Furthermore the line    if(mySerial.read()<400)    is always true
as serialRead() returns a int  representing a char which is in the range 0..255  (and -1 if there is none)
Code: [Select]
int val = 0;
  bool ready = false;
  mySerial.listen();
    int c = mySerial.Read();
    switch(c)
      case '0'..'9': val *= 10 + c - '0'; break;  // add up individual chars to a numeric value
      default: ready = true;
    if (ready)
      if (val < 400)
        //do something
      else if (val > 900)
        //do something else
        //do something completely different
      val = 0; // reset;
Rob Tillaart
ThunderWiring
thanks man! i manipulated your code a little and got mine to function properly!
you were right, if(mySerial.read()<400)  is always true statement..
i used your approach of storing the char, switch/case it and then setting the boolean value for the 'if' statements..
Regards,
ThunderWiring
robtillaart
Quote
Maybe post your working code for future reference for people who find this thread interesting?
Rob Tillaart
ThunderWiring
since i wanted to compare the analog value, i did the comparison on the TX board, and sent a char over mySerial('f' for false or 't' for true) to the RX board, there on the RX i stored that char, then used switch\case to set a boolean flag for the 'if' statements..
it worked fine!
tx:
Code: [Select]
if(value<450)
    mySerial.write('f');
  if(value >900)
    mySerial.write('t');
rx:
Code: [Select]
char RXdata; boolean flag=false;
  mySerial.listen();
    RXdata = mySerial.read();
    switch(RXdata)
      case 't':
                flag=true;
      case 'f':
                //flag = false;
  if(flag)
  {// do something}
  else{//do something else}
Regards,
ThunderWiring
