Topic: Bit Angle Modulation problem (Read 3678 times) previous topic - next topic
Vinter
Hello everyone,
?t's late and I got a serious headache trying to solve this.
basically I tried to optimize my code a bit by getting rid of a switch statement.
When like this, the whole program works perfectly:
(the led array contains bytes)
  ISR(TIMER1_COMPA_vect) {
    if (BAM_Counter == 1){
    BAM_Bit++;}
    else if (BAM_Counter == 2){
    BAM_Bit++;}
    else if (BAM_Counter ==4){
    BAM_Bit++;}
    else if (BAM_Counter ==8){
    BAM_Bit++;}
    else  if (BAM_Counter ==16){
    BAM_Bit = 0;
    BAM_Counter = 0;}
    BAM_Counter++;
    switch (BAM_Bit) {
     case 0 :
     for (int col =0; col <9; col++) {
           PORTD_CATHODES = 0;
           PORTB_CATHODES = 0;
           ANODE =0;
    for (int row =0; row <9; row++) {
         if (led[col][row] >> 0 & 1) {
           ANODE = pgm_read_byte(&(PIN[col]));
           if (row < col && row <5) {
             PORTD_CATHODES = PORTD_CATHODES | pgm_read_byte(&(PIN[row]));
           else if (row < col && row >= 5) {
             PORTB_CATHODES = PORTB_CATHODES | pgm_read_byte(&(PIN[row]));
           else if (row >= col && row <4) {
             PORTD_CATHODES = PORTD_CATHODES | pgm_read_byte(&(PIN[row+1]));
           else if (row >= col && row >= 5) {
             PORTB_CATHODES = PORTB_CATHODES | pgm_read_byte(&(PIN[row+1]));
       if (col < 5) {
       DDRD = (DDRD & 3) | (PORTD_CATHODES & B11111100) | ANODE;
       PORTD = ANODE;}
       else {
       DDRB =  PORTB_CATHODES | ANODE;
       PORTB = ANODE;}
     break;
     case 1 :
           PORTD_CATHODES = 0;
           PORTB_CATHODES = 0;
           ANODE =0;
         if (led[col][row] >> 1 & 1) {
       if (col < 5) {
       PORTD = ANODE;}
       else {
       PORTB = ANODE;}
     break;
     case 2 :
           PORTD_CATHODES = 0;
           PORTB_CATHODES = 0;
           ANODE =0;
         if (led[col][row] >> 2 & 1) {
       if (col < 5) {
       PORTD = ANODE;}
       else {
       PORTB = ANODE;}
     break;
     case 3 :
           PORTD_CATHODES = 0;
           PORTB_CATHODES = 0;
           ANODE =0;
         if (led[col][row] >> 3 & 1) {
       if (col < 5) {
       PORTD = ANODE;}
       else {
       PORTB = ANODE;}
     break;
     case 4 :
etc...
but when I change it to
    BAM_Bit++;}
    BAM_Bit++;}
    BAM_Bit++;}
    BAM_Bit++;}
    BAM_Bit = 0;
    BAM_Counter = 0;}
    BAM_Counter++;
           PORTD_CATHODES = 0;
           PORTB_CATHODES = 0;
           ANODE =0;
         if (led[col][row] >> BAM_Bit & 1) {
       if (col < 5) {
       PORTD = ANODE;}
       else {
       PORTB = ANODE;}
it doesn't work. Any thoughts?
Thanks in advance.
tobyb121
When you say doesn't work, do you mean it doesn't compile or doesn't do what you expect?
Vinter
It does compile but it doesn't do what I want. What confuses me is that it shouldn't work differently than it's switch version. What may be happening is that the interrupt takes more time to run with the no switch version since it has to pass the BAM_Bit variable first and then swift the bits, leaving no time for anything else to occur. I am calling the interrupt as fast as it goes in the switch version so it's not unlikely if it takes many more cycles to pass the variable data.
nickgammon
Call me obsessive, but I find that code hard to read. Please use code tags, and not "copy for forum" in the IDE. Also please do not put the closing "}" on the same line as other code.
Can you post the whole sketch? Maybe something not shown is the reason, for example a missing volatile keyword.
Vinter
I actually intended to post the whole sketch and I commented everything but the forums don't let me post it because of the character limit. It's why I didn't include any commends and I admit the code is hard to read since I'm using it for a charlieplexed 3d led cube while taking advantage of two ports to control the anodes. If you can tell me how to post the whole code I will gladly do so. By the way, reducing the interrupt frequency seems to fix the problem. Also sorry for the brackets closing in the same line, I didn't notice that.
AWOL
I'm not aware of any character limit for attachments.
nickgammon
How to use this forum
Vinter
